Old 01-22-2003, 09:05 AM
jsampedro jsampedro is offline
Default Consolidate Regions is \'grayed\' out
I am trying to consolidate a several regions on a track and am unable to because the command is grayed out on the toolbar. I also will not work when I use the keyboard shortcuts.
I am using an MBox on a PC platform.
Old 01-22-2003, 09:11 AM
Roy Howell Roy Howell is offline
Default Re: Consolidate Regions is \'grayed\' out
So, it's still gray after you've highlighted these regions? I have to that first, as elementary as it is.
rh music
Old 01-22-2003, 09:37 AM
Yep,
I select all the regions I want to consolidate and it is still 'grayed' out. I looked on the users guide, but couldn't find anything to help me.
Calvin Calvin is offline
Yah this same thing happened to me, I didn't realize that consolidating regions was actually a functions of the digidesign pluggins that come with the program. After I uninstalled the pluggins, (yah by accident) I found I couldn't consolidate regions. To get the function back you simply have to reinstall pro-tools with all of the digi pluggins.
Calvin
Old 01-22-2003, 09:50 AM
Yeah, actually, I had uninstalled the plugins that had 'run' out so that I wouldn't get the same message each time i started PT.
I kept the Digidesign plugins in there though. Do you happen to know which plugin relates to the consolidation feature?
Old 01-22-2003, 09:58 AM
I have no Idea, I just reinstalled the program with all the basic pluggins.
Calvin
Old 01-22-2003, 10:29 AM
Thanks Calvin,
I will do that when I get back to the studio and hope that was all it was.
Old 01-22-2003, 10:33 AM
Audiosuite "duplicate".
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
MIDI Regions Grayed Out? philip888 MIDI 15 10-17-2018 06:50 AM
Consolidate Regions issue marrap Pro Tools TDM Systems (Mac) 9 09-11-2010 03:26 PM
Select Grayed Out In The Regions Menu? eldusto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-14-2007 03:32 PM
consolidate regions help lala 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-24-2003 12:22 AM
best way to consolidate regions smlworld Pro Tools TDM Systems (Mac) 3 05-21-2001 10:35 AM
