Old 04-01-2015, 03:06 PM
vocalvoodoo's Avatar
vocalvoodoo vocalvoodoo is offline
Default PT 11/12 bug
I do quite a bit of half speed recording for pitched cartoon voices, but as a recent PT11 and 12 upgrade user I'm seeing them both impart tons of clicks and pops, but 10 does not. Anyone else noticing that? Any ideas?
I've tried different sample rates and buffer sizes, which the 2048 buffer setting helps a bit, but there are still artifacts. I've also tried ignoring errors which also helps a tad too, but not enough to have usable recordings.
Despite that problem, I'm liking 12 a lot. Snappier and lower CPU usage in the sessions I've A/Bed with 11.
Mac Pro 4,1 2.66 quad
16gb Ram
Yosemite 10.10.2
Old 04-01-2015, 03:18 PM
junkerde junkerde is offline
Default Re: PT 11/12 bug
change to polyrythmic
Old 04-01-2015, 03:33 PM
thanos4 thanos4 is offline
maybe lowering the event sensitivity from elastic properties
Old 04-01-2015, 03:41 PM
Thanks for the responses, guys. I'm not using elastic audio, though. I'm talking recording at half speed (shift+command+space) so playback will be double speed and pitched up.
If I'm being dense, please forgive me.
