Old 09-23-2002, 04:14 PM
Paul Bee Paul Bee is offline
Default Audio Solutions 4 G3 266 Mhz System
I have 2 G3 266Mhz Machines I would like to record vocals with. I am aware these machines are dated but I am running a g4 @450Mhz with a 001 fine. What would you suggest I do with these systems. Would a Tool Box System run at this speed? Delta, Echo???? Help
Old 09-23-2002, 06:38 PM
John H John H is offline
Default Re: Audio Solutions 4 G3 266 Mhz System
I'm running a 300Mhz beige G3 with 320Mb of RAM, 60 Gb deskstar 120GXP (audio only drive) the stock 6Gb drive for the OS and a Toolbox XP system runs fine.
In the Dave C test I can run 6 tracks at 24bit with 5 plug-ins on each track (4 bandEQ, Compressor, Medium Delay, Long Delay, Slap delay)
As far as RAW recording potential with only a few effects, I can record to either 24 or 32, 24bit tracks depending on if I'm running the beta or not and that leaves me with enough CPU power to run 10 - 15 plug-ins. I can even manage 2 instances of Dverb in most sessions if I havn't use too much automation and I've been printing to audio and turning plug-ins offline as I go along.
hope this helps.
I was running fine with 192Mb for ages and going upto 320 has made things smoother but not noticably improved the number of plug-ins I can manage in a typical session.
UGH! ''DAE can't get audio from drive fast enough.'' Tried many different solutions! Niglopte 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-23-2014 06:35 PM
Is a Sonic Solutions system better for mastering than PT HD? jaffaman Pro Tools TDM Systems (Mac) 2 04-25-2003 03:10 AM
Is a Sonic Solutions system better for mastering than PT HD? jaffaman Pro Tools TDM Systems (Mac) 5 04-24-2003 02:55 PM
"Audio too Dense" problem - Are these possible solutions? Sparky1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 19 12-07-2002 10:05 PM
Other Hardware Solutions for Logic Audio? relaxo Pro Tools TDM Systems (Mac) 3 07-30-2000 12:23 AM
