Old 09-07-2015, 03:49 AM
Mubeau Mubeau is offline
Default where is menu "copy and relink"
hey,
I´m in the session Workspace and selected some files which are on another drive.
in PT10.xx you could now use the menu on the far right "copy and relink".
Then all files which were on other drives were copied to the session "audio files" folder and relinked there. (extremely useful if you work with big sessions and don't want to "copy session in" all the time).
but this menu point is gone. Where is it? Didi they drop it?
thanks!!
m-.
Old 09-07-2015, 05:07 AM
Stig Eliassen's Avatar
Default Re: where is menu "copy and relink"
Hi.
Not a feature that I use, but I believe you need to create a catalog first. Then you can right-click the catalog itself, or files within that catalog, and choose Copy and relink.
Old 09-07-2015, 07:47 AM
gwhatley's Avatar
gwhatley gwhatley is offline
In the Workspace, choose Session Audio Files. If you sort by Path, you can fairly easily select files from other drives, then right-click to choose "Copy and Relink".
Garrard Whatley
Seismic Post Audio
Post Audio for Film and Television
System/Hardware Info
IMDb credits
Old 09-07-2015, 08:45 AM
Yeah, this used to work with a control-click, but now it has to be an actual right-click, so if your trackball/mouse isn't set up for right-click you'll have to add it.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 09-07-2015, 08:49 AM
hi! ok it was right click (something i switched off for PT, cause i had this on "control". so i had to reactivate this on the mouse, cause it has been removed from the "short menu".
thanks!
m.
Old 09-07-2015, 06:44 PM
coolness - I think this was just a programming mistake as every other right-click function also works with control-click.. this one broke at 11. Threw me for a loop for a bit...
Still can't find "Low Latency Monitoring" in my menu options... finalcut Pro Tools 10 13 02-20-2013 11:52 AM
contextual menu appears by "accident" KK Proffitt Post - Surround - Video 2 12-03-2011 01:51 AM
Bug using "Save As" and Title-bar Path Menu dkrz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-19-2009 07:03 PM
"automatically find and relink" craigdwlr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-11-2008 10:48 PM
"Save Session Copy" MUST copy AIIFF files??? BHeller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-11-2001 12:33 AM
