  #21
Old 10-14-2014, 11:24 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: AAE -9173 Issues
I noticed something similar when I upgraded to 11.2.1. PT11 would not load. I removed PT10 app and everything worked fine.
There are still remnants of PT10 in the system so I guess the best rout is to uninstall all PT stuff and re-load 12.2.1
Originally Posted by deadshot View Post
If you ran pt10 and upgraded to OS x on your Mac, they do not play well together. Pt10 needs to be removed in every way. This can cause all kinds of issues. this seemed to be the real fix, I had some residuals left over and not sure why they didn't get removed. Also just placing them in your trash does not kill them, you need to empty them out.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
  #22
Old 10-14-2014, 03:56 PM
CygnusX-1Bk2 CygnusX-1Bk2 is offline
So the fix is a defeated purpose of having co-installs of 10 and 11? WTF?!?!?
I will choose,
Freewill
http://jimdiazaudio.com/
  #23
Old 10-14-2014, 04:10 PM
mesaone mesaone is offline
Well, co-install is not supported on Mavericks. The consolation is that most plug-ins are now available in AAX 64 bit, so the transition from PT10 to PT11 is mostly seamless for many people. There are a few stragglers in the plug-in world, but such is life.
Deadshot didn't specify whether he removed PT10 prior to upgrading to Mavericks, but if he did not then that might explain the issues he experienced... Although to be honest, his issue was exceptionally strange and I can completely empathize with his frustration.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
  #24
Old 10-14-2014, 04:39 PM
But it is supported on 10.8.5 where the problem originated for me. And the uninstaller for 10 doesn't work in Mavericks. This is a serious cluster [bleep][bleep][bleep][bleep] on Avid's part.
I will choose,
Freewill
  #25
Old 10-14-2014, 05:05 PM
Manually uninstalled 10 from my Mavericks drive as directed by the Avid knowledgebase doc. Still -9173 during bounce.
I will choose,
Freewill
  #26
Old 10-23-2014, 06:47 PM
H.Slin H.Slin is offline
I signed up for DUC specifically to post on this issue. I have all these same exact problems in both Pro Tools 10 and 11. I have tried every suggested "fix", and put up with reading all the ridiculous posts from the people who think they know everything about what me and others with the same problem are doing "wrong". My system is more than tough enough to handle the sessions it is crashing on. I've removed the plugins from their folder, replaced them, unplugged all peripherals, tried aggregates, built-in audio and interfaces, uninstalled, re-installed both os and PT, trashed the preferences…..not to mention the likelihood that all my neighbors are now terrified of me from the rampant screaming and swearing incessantly pouring from my home. There seems to be absolutely no answer to fix the problem. It seems clearly to be a bug, and the program is close to unusable. Bounce to disk in real time? forget it. So the question is very quickly becoming not "when will this problem be addressed", but what other DAW should I transition to. I really prefer Pro Tools and have been working with it since version 5, but man, this is not looking good.
  #27
Old 10-23-2014, 08:22 PM
We're just trying to help. Sorry you had to read some forum posts that didn't help fix your problem. Since this error is not present for everyone, not even present for everyone on similar systems, then it's always possible that it is user error or third-party incompatibility.
On the other hand, you can't expect people to intuit your situation if you don't post anything specific. That's the reality of troubleshooting.
  #28
Old 10-24-2014, 01:19 AM
Rolling back to 11.1.3 solved the problem for me. We'll see what the next "fix" breaks/resolves. Hopefully this is in the mix.
I will choose,
Freewill
  #29
Old 10-24-2014, 09:31 AM
Don't get me wrong, I greatly appreciate the people genuinely trying to help, which is why I spend hours on here reading and trying out the suggestions. The reason I never joined before is because I can usually find the answer to my problem fairly quick, so there has really been no need for me to ask questions. I've read enough on this subject now, to where it seems (to me) pretty clear that it's a bug, and not user error, which is why I did not post any specifics about my system. So, I guess I was just trying to sympathize with others having this same problem, as well as adding my voice to the need of it being resolved. You do have to admit that it is frustrating to come across a comment rudely suggesting to someone that all you need to do is increase the playback buffer or the like (not in this thread, but countless others both here and on other forums). I'd just like to see this problem resolved so I can get back to work, and if I come across anything that helps I will gladly share that information.
  #30
Old 11-18-2014, 01:09 PM
john1192 john1192 is offline
Cygnus .. are you still using 11.1.3 ??
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
AAE 9173 Pro Tools ran out of CPU power Kinh Pro Tools 11 223 12-10-2017 09:39 AM
Pro Tools 11.1.0 AAE-9173 Error justus1900 Pro Tools 11 4 12-22-2015 02:46 PM
11.2.1 My Findings, -9173 error with BTD Intransit Pro Tools 11 77 11-23-2014 04:12 PM
PT 11 Clearly Not An AAE 9173 Error rgconrad1 Pro Tools 11 3 09-29-2014 11:56 PM
Aae-9173 txrx Pro Tools 11 5 12-28-2013 04:34 PM
