Old 02-15-2013, 09:22 PM
oldtracy oldtracy is offline
Smile MIDI Setup - Not seeing USB Audio Device as an Input Port Option
Hi and Thanks for the help!
I'm trying to run my Yamaha P-105 as a midi device. I have the latest driver installed. When I go to MIDI Studio Set-up I'm only seeing the following as Input Ports: FW 002 MIDI 1 (In/Out), FW 002 MIDI AsynchMidiControl and FW 002 MIDI MidiControl.
From the research I've done it seems that I should see USB Audio Device as an option.
Any ideas about how I can adjust my set-up so I can start using my P-105 for MIDI?
Thank you!!
System Stats:
HP Pavillion
Windows 7
Pro Tools 8.5
Digi 002
Audio MIDI setup says DIGI 002 midi device is offline oliarnalds MIDI 17 10-23-2016 10:13 PM
Rename Midi input devices: USB Audio Device (4)[Emulated] - ugh! Herkimer MIDI 1 03-23-2009 03:49 PM
USB MIDI device connection - Mac Audio MIDI Setup jongilbertson MIDI 2 06-11-2008 10:13 PM
Midi problem - no INPUT DEVICE option in MIDI menu tam103 MIDI 2 01-05-2007 08:01 AM
Audio Midi Setup can't locate my device rockwithrespect 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-15-2004 11:03 AM
