How to Join & Post    Community Terms of Use    Help Us Help You
Knowledge Base Search    Community Search    Learn & Support
Old 01-04-2021, 07:18 PM
unkJE's Avatar
unkJE unkJE is offline
Default Re: PT 2020.12 Occasionally stopping playing - Windows update service?
Originally Posted by guitardom View Post
I recommend keeping a shortcut to your network adapter on your desktop.....
Great Tip!
Happy New Year, Steve – and thanks for all your help in the past – may 2021 be good for you and all yours – including your wonderful TRASHER app!
I love my Lenovo W520’s small network adapter ON-OFF switch on the front-left side panel!
It’s normally switched OFF for Pro Tools
It’s presently permanently switched OFF for everything, until Pro Tools supports Windows 10, version 20H2
In
Control Panel\All Control Panel Items\Administrative Tools
I click on “System Configuration
In the “Services” Tab in “System Configuration”, I check the box: “Hide all Microsoft services” – click the word “Manufacturer” at the top – then uncheck the lot – except Apple’s “Bonjour Service”, Avid’s “Mbox Pro Audio Device”, Conexant Systems Inc. (my on-board Audio) “Conexant Audio Message” and PACE Anti-Piracy Inc.’s “PACE Licenses Services”.
Hit “Apply” then “OK”
Restart computer
(However, DUC-Meister Deluxe (Darryl Ramm), whose diverse opinions are highly respected, advises against this move.
I must ask Darryl: “Why is this?”)
Pro Tools 2020.12 and 12.5.1 HD - Studio One 5 Pro - Win10 64 Pro Lenovo W520 ThinkPads & 433830U Docks Mbox 3 Pro - Axiom Pro 49 - AIR Mini 32
Old 01-04-2021, 08:57 PM
I must ask Darryl: Why is this?)
Uh. I am not sure of the exact reference here, but generally I am a fan of going with Windows 10 Pro and using that to disable those toxic updates. I think I have suggested not trying to mess around and doing it properly. Do what works for you but doing nothing and being screwed over by Windows updates is not fun.
Old 01-04-2021, 09:18 PM
unkJE's Avatar
Thanks for clarifying - appreciate your ideas!
Old 01-05-2021, 10:52 AM
TOM@METRO's Avatar
Perhaps I've just been lucky, but Windows updates have not negatively affected Pro Tools for me in recent history. I'm currently up to date, and have no issues.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2020.12 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 01-05-2021, 12:40 PM
The Weed's Avatar
The Weed The Weed is offline
Same here. The only issue I had was quite a while back when one update caused pops and clicks in my audio. Checked with LatencyMon, found the issue, did a web search, found the solution - roll back a certain KB update - fixed.
Since I now use Processor Affinity, no issues with any update. I do have updates turned off on my Audio computer, but update as soon as I know there is one - after making an image I can restore that removes the update, just in case.
As always, YMMV.
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 01-06-2021, 10:05 PM
tvon tvon is offline
Hi Guys - I have a 2020.11 install on a new windows machine (completely patched) and i'm getting intermittent play back/record stoppages. When it happens, it slowly lurches play forward and becomes completely unresponsive. Or it stops mid recording take.
It happens almost ALL the time, esp if PT sits open for a while. When this happens, no error messages are displayed and the CPU/Memory are not pegged. In fact barely used. I can post all the specs of my machine but suffice to say, its faster than another machine i have and it never has issues. Both are on version 20H2.
The only difference is this new machine does not have internet connectivity. Could version 20H2 of windows be to blame? If thats the case, is there any indication that version 20H2 will be supported or directions to downgrade OS?
thanks.
Old 01-06-2021, 11:45 PM
TOM@METRO's Avatar
As always, YMMV.
A smart practice.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 01-07-2021, 10:43 AM
EGS's Avatar
EGS EGS is offline
No issues with 20H2 here.
Desktop: PT 2020.5 / Win 10 / GIGABYTE GA-X58A-UD3R / i7 hex 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 2020.5 / Win 10 / HP ProBook / i7 quad / U-PHORIA UMC1820
Legacy: PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI001
Click for demo
Old 01-07-2021, 12:18 PM
thanks.
use the program Latencymon. It should be able to tell you what drivers are causing problems.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 9900k
Win 10
Old 01-08-2021, 09:26 PM
Hey - So i did as you suggested.. two things I found.. First i'm not actually on version 20H2 on this machine. But i did upgrade to 2020.12 in hopes it would help. No dice. It froze up on a brand new session just one track playing, no plugins. I ran Latency Mon and it said this. I'm not sure what driver i'm looking for, maybe NVidea or igcctray.exe?
CONCLUSION
__________________________________________________ __________________________________________________ _____
Your system appears to be suitable for handling real-time audio and other tasks without dropouts.
LatencyMon has been analyzing your system for 0:00:24 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: PROTOOLS
OS version: Windows 10, 10.0, version 2009, build: 19042 (x64)
Hardware: OptiPlex 3070, Dell Inc.
CPU: GenuineIntel Intel(R) Core(TM) i5-9500 CPU @ 3.00GHz
Logical processors: 6
Processor groups: 1
RAM: 16193 MB total
CPU SPEED
Reported CPU speed: 30 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (s): 230.40
Average measured interrupt to process latency (s): 3.007542
Highest measured interrupt to DPC latency (s): 201.60
Average measured interrupt to DPC latency (s): 1.077705
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (s): 725.440
Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0.117092
Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%) 0.119881
ISR count (execution time <250 s): 5813
ISR count (execution time 250-500 s): 0
ISR count (execution time 500-1000 s): 2
ISR count (execution time 1000-2000 s): 0
ISR count (execution time 2000-4000 s): 0
ISR count (execution time >=4000 s): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (s): 272.1590
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 457.07 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.035597
Driver with highest DPC total execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%) 0.125382
DPC count (execution time <250 s): 73011
DPC count (execution time 250-500 s): 0
DPC count (execution time 500-10000 s): 2
DPC count (execution time 1000-2000 s): 0
DPC count (execution time 2000-4000 s): 0
DPC count (execution time >=4000 s): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: igcctray.exe
Total number of hard pagefaults 6
Hard pagefault count of hardest hit process: 6
Number of processes hit: 1
PER CPU DATA
CPU 0 Interrupt cycle time (s): 1.039810
CPU 0 ISR highest execution time (s): 725.440
CPU 0 ISR total execution time (s): 0.172628
CPU 0 ISR count: 5815
CPU 0 DPC highest execution time (s): 272.1590
CPU 0 DPC total execution time (s): 0.178123
CPU 0 DPC count: 72382
CPU 1 Interrupt cycle time (s): 0.777938
CPU 1 ISR highest execution time (s): 0.0
CPU 1 ISR total execution time (s): 0.0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (s): 31.916667
CPU 1 DPC total execution time (s): 0.000723
CPU 1 DPC count: 178
CPU 2 Interrupt cycle time (s): 0.697483
CPU 2 ISR highest execution time (s): 0.0
CPU 2 ISR total execution time (s): 0.0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (s): 35.2170
CPU 2 DPC total execution time (s): 0.000786
CPU 2 DPC count: 217
CPU 3 Interrupt cycle time (s): 0.619862
CPU 3 ISR highest execution time (s): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (s): 32.653333
CPU 3 DPC total execution time (s): 0.000523
CPU 3 DPC count: 128
CPU 4 Interrupt cycle time (s): 0.606402
CPU 4 ISR highest execution time (s): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (s): 11.749333
CPU 4 DPC total execution time (s): 0.000136
CPU 4 DPC count: 41
CPU 5 Interrupt cycle time (s): 0.605757
CPU 5 ISR highest execution time (s): 0.0
CPU 5 ISR total execution time (s): 0.0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (s): 32.463667
CPU 5 DPC total execution time (s): 0.000259
CPU 5 DPC count: 67
1/14/2020 - Important Service Notice marianna General Announcements 0 01-14-2020 08:16 AM
Public Service re windows update albee1952 Windows 3 03-12-2018 03:57 PM
What easy fix for a session occasionally stopping from running out of CPU power? bill60532 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 07-27-2011 08:01 PM
Protools 8.0.5 update stopping (downloading that is) Hotcrazyfruit General Discussion 1 05-16-2011 07:33 PM
Itunes 7.4.1 update stopping Pro tools from opening martyk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-21-2007 06:00 PM
