Old 12-22-2010, 11:42 PM
nxtvanhalen nxtvanhalen is offline
Default Bounced WAV doesn't translate PT 9
When I bounce my project the wav file is drastically different then what i heard during bounce and what I mixed.
It was recorded off of a LS9 through a Dante card, at 48/16 and I bounced both at 48/16 and 44.1/16 and both don't translate.
Thoughts?
Old 12-23-2010, 12:58 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: Bounced WAV doesn't translate PT 9
Is it drastically different or are you listening to it through a different sound card and through iTunes possibly? How is it different?
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 12-23-2010, 01:02 AM
I listened to it in protools when I pulled it back in, and in Finder. its mix and pans and fades etc are all different from what I mixed and what I heard during bounce
Old 12-23-2010, 02:02 AM
caruso7r caruso7r is offline
Are you bouncing stereo interleave and converting after the bounce? Did you put "Dither" across the master buss? Or are you bouncing with the same bit rate? Give us details on exactly how you're bouncing and make sure you DO put a "Dither" plug across the master buss if you ARE changing the bit rate.
John
Pro Tools 12.5
Macbook Pro & Windows 7 Ultimate 64 Bit
Old 12-23-2010, 10:12 AM
I put dither on the main out, NO difference, I have tried every combination of bouncing and still nothing, they still bounce with out translating my mixes, very odd....
Old 12-23-2010, 10:31 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Is it possible that you are bouncing something other than the 1 & 2 main outs? Maybe that is why you are hearing one thing on the bounce but actually bouncing another signal path?
Did this just start to happen or has it always happened?
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 12-23-2010, 03:56 PM
Slim Shady Slim Shady is offline
I would bet it's something along these lines. Your bounce source is probably different than your monitoring source.
Old 12-23-2010, 06:43 PM
I checked in all my out put settings... didn't seem to see anything odd.... not sure I would know how to bounce something other then what im hearing....
all my channels are set to output 1-2 and so is my main out.... all my inputs are N/A because my hardware ware isn't hooked up.
im trying a "Save Copy as" and seeing if that works.....
Old 12-23-2010, 07:20 PM
I also checked back on several other projects I have been working on but hadn't tried to bounce, one of them worked.... one had same problem, my only thought is, the one that worked had not been edited, the one that didn't had.... any correlation?... possibly a plug in issues? the "save as a copy" didn't help...
Old 12-23-2010, 08:01 PM
KMcK KMcK is offline
We're not talking about inputs/outputs within the session, we're talking about the "Bounce Source" in the Bounce To Disk window. I've seen it randomly get changed to a bus or alternate output path for no reason before, so check to make sure that your Bounce Source is set to output 1-2 and hasn't accidentally been switched to something else. If it's set to say Bus 1-2 instead of output 1-2, you'll hear your bounce fine as it goes down since you're monitoring through Output 1-2, but the bounced file will only have whatever was being sent to Bus 1-2 in it.
Unable to translate tracks IsaacAustin Windows 10 09-17-2013 03:10 PM
Volume Trim translate to LE? KingFish Pro Tools TDM Systems (Mac) 1 02-03-2009 09:34 AM
Translate PAL to NTSC ProTooler Post - Surround - Video 10 01-18-2007 11:00 AM
Getting your mixes to translate... Ssaidvox1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-18-2003 09:44 PM
programs to translate a .wav into midi Bastiaan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 36 08-24-2002 02:04 PM
