Old 12-01-2010, 12:54 PM
Tobsen Tobsen is offline
Default Video sync problems with PT9
Hello
Today i noticed, that i have serious sync problems with video in PT 9.
with ADC on, and ( for example) a noise reduction tool like x-noise on a audio track, my video isn't in sync anymore
Also my delay indicator light is nearly ALWAYS red, which means i'm running out of samples if i understand that right.
in the playback menue, ADC is set to "long" per channel
I mean, can this be? I don't use that much plugs on a normal post production session, some oxford compressors and ssl eqs, maybe some verbs or delays, that's it.
I thonk it's a problem with the video in PT9, cause audio is delayed perfect but the video isn't.
Anyone can help me or have some ideas?
My system is a mac pro quad 2Ghz, 5gb ram, OSX 10.6.4. Digi 002
Old 12-02-2010, 12:20 PM
jazzdrumr jazzdrumr is offline
Default Re: Video sync problems with PT9
Do you have a video sync offset set? are you working to Quicktime or external video?
Old 12-03-2010, 12:48 AM
No i have not set a video offset...
should i do that? what value sould i use then?
videos are quicktime format
thx for your reply
Old 12-19-2010, 03:19 PM
Ruthven Ruthven is offline
Part of your problem might be X-Noise, if I recall correctly it causes a massive delay, even beyond the scope of Delay Compensation to sort out, so it might be your audio being out of sync with your picture, rather than the other way round. Probably best used as Audiosuite render on a duplicate of your edited track.
Old 12-19-2010, 04:20 PM
Slim Shady Slim Shady is offline
+1 to Ruthven's statements.
To clarify -
'Long" Delay Compensation only compensates for up to 4095 samples per channel.
X-Noise induces 5120 samples of delay.
Thus if you use X-Noise as RTAS, it's going to delay your audio.
sync problems with Video Satellite LE CD Productions Post - Surround - Video 5 05-16-2011 01:22 PM
Keeping Laybacks in Sync (delay compensation and Video sync offset) edit machine Pro Tools TDM Systems (Mac) 6 11-15-2010 11:33 AM
Video Satellite LE Sync Problems jmattchan Post - Surround - Video 12 08-22-2009 09:45 AM
PC video sync problems Matt Stutter General Discussion 2 05-12-2002 08:21 AM
PC video sync problems doey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-09-2002 12:51 AM
