HELP - PT getting slower the longer its open!
Hey all!
I noticed a very strange thing the last few days: the longer PT is open, the slower it reacts! If I hit any command, or even move the mouse over different areas, where the mouse changes, or whatever I do, after an hour or so it takes up to 5 seconds until PT does what it should! normally it does all things instantly. Other programs react not in this manner. My system is clean and set to all PT references, I reformatted it this evening to see if it still applies - and it does. I have a Shuttle X PC 1,8 GHz, 1,5 GHz RAM, 7200 internal and FW drive. PT 6.7cs4. Only PT is installed - no other progs!!! Hardware is 002r. I can´t understand why it does so! If anyone´s got an idea, I´ll be (as always) very thankful. Cheers, Andi
ReRecording Mixer & Venue D-Show Live Sound & Recording Engineer www.audio-machinery.com |
Re: HELP - PT getting slower the longer its open!
If you've got 1.5G of ram... try disabling your windows system Page file for your OS drive, and see if that helps.... let us know.
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
I just noticed - the effect is just within a file! If I open a different file, it´s OK, until some time passes! If I close a file, that has the effect, save it and open it again, the effect is gone. I save very often, almost after every step I do. So this cannot be it. This is very strange...
Are you using a d-verb in your session out of curiosity ??? is your X-PC a Pentium 4 ??? are you viewing your "System Usage" window from the "Windows menu" in Pro-Tools ???
To shut off your page file you go to control pannel <--- System <--Advanced tab <--Performance -- Settings Button <---Advanced tab <--click on the CHANGE button under Virtual Memory. Select the radio button NO Paging File with your C drive highlighted in the top window. Hit the SET Button. "OK" and "APPLY" out of all your dialogs, and re-boot your system. If this doesn't help... to turn it back on, just walk through all those steps again, and select the "System Manages Size" with your C drive Highlighted, and hit SET, and apply and ok your way out of all dialogs again. Let me know about the P4 / D-Verb / System Usage window thing.
You might try disabling your power saving settings. Either in the control panel, or better yet in the bios.
OT: Is ML really that much slower than SL? | gtomassetti | macOS | 24 | 05-04-2013 09:21 AM |
Plugins slower to open after 9.0.3 update | crizdee | Pro Tools TDM Systems (Mac) | 5 | 06-02-2011 10:48 AM |
Help needed! Session will no longer open! | Martin Dubka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-16-2010 01:47 PM |
7.3.1 LE will no longer open? | guitarplayer546 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-22-2007 05:59 PM |
PT 7.2 with slower G4? | Ivo222 | Pro Tools TDM Systems (Mac) | 7 | 09-22-2006 01:16 AM |
