Old 03-27-2021, 01:26 PM
off the wall's Avatar
off the wall off the wall is offline
Default Re: 2021.3 new bug?
Originally Posted by Micks_Mix View Post
In the reademe Avid says that there are some changes in the dialog (shortcuts) for BS compatibility.
However, it would be interesting if there is someone on Mojave and could test the browsing issue. Maybe this is just a side effect of the changes that was not found in test.
Expanding folders seems to work (good workaround), only double clicking on a folder does not work anymore. And I have the "open twice" issue as well.
On Mojave, double clicking does not open folders in the import dialog. Command O does though. I also have to hit Open a second time to complete the import. Something is broken there...
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 03-27-2021, 02:19 PM
Micks_Mix Micks_Mix is offline
Ok... seems to be obvious that there is an issue (or more) in the import audio dialog. Would be great if Digi Support confirmed, that it's not a machine related problem but a 2021.3 bug. At least there are workarounds.. so not a severe bug, but really annoying...
Pro Tools|HDX Ultimate, 192 HD I/O, 192 HD Digital I/O, Focusrite OctoPre, Pro Tools 2021.3, Mac Pro 5.1, 24 GB RAM, Mojave
Old 03-27-2021, 04:08 PM
Sonopolis Sonopolis is offline
How about the other Import dialogues? Session, Data, Video, MIDI? Does it work there? Else this would keep me from updating.
Old 03-27-2021, 04:20 PM
Import session data works normally on Mojave... did not test MIDI and video... I am pretty sure it has something to do with the redesign of the import audio dialog.
Old 03-27-2021, 05:47 PM
Seems to be confirmed now...
  #16
Old 03-27-2021, 06:19 PM
All the other import, open and save dialogs work normally. It seems Avid rolled their own on the audio import dialog rather than using the standard Apple API. Most likely to provide the audio preview function.
  #17
Old 03-27-2021, 11:07 PM
[email protected] info@npp.co.uk is offline
Same here - Import Audio window a mess. Running Big Sur.
Also Save As command - the cursor was always on the name dialog. Now it's somewhere else
  #18
Old 03-27-2021, 11:36 PM
Cacov's Avatar
Cacov Cacov is offline
I confirm the bug exists.
Mojave 10.14.6
macOS Mojave | Avid Pro Tools Duet, Apogee Groove & Symphony I/O | Pro Tools Studio 2022
Sound Engineer | Non-Avid Employee
  #19
Old 03-28-2021, 02:08 AM
lae777 lae777 is offline
Mojave 10.14.6
Yep. Me too.
5,1 Mac Pro, 3.46 GHz Six Core Xeon, 48gb ram, Pro Tools Ultimate 2023.6, HD Native card, Avid 192io interface, Avid 96io, Intensity Pro video card, Radeon HD 7950 graphics card, Mac OS Monterey 12.6.7.
  #20
Old 03-29-2021, 11:19 AM
Eric Lambert's Avatar
Seems to be ok here (knocks on wood). 2021.3 w/ Catalina.
Import Audio crashes PT Ultimate 2021.x Metalgez Pro Tools 11 07-03-2021 12:42 AM
Double Clicking on Aux Track doesn't open Track Color window atothegreen Pro Tools 2018 17 03-28-2018 03:34 PM
Crash when double clicking to create new track while recording audio DJ Hellfire Pro Tools 12 4 04-20-2016 10:44 AM
Importing Audio by double clicking a clip defaults to Add relder17 Pro Tools 10 7 09-08-2013 09:29 AM
