  #71
Old 07-24-2019, 11:23 AM
Ghost In The Attic's Avatar
Ghost In The Attic Ghost In The Attic is offline
Default Re: NVMe upgrade for Mac Pro 4.1/5.1 Mojave
Rather get the info before breaking seals on cards, etc...
Working is not the same as working optimally. I’d rather know before proceeding.
I am really hoping somebody can chime in. Flight, are we go or no go?
Retro 176 (pair), Pultec EQP-1A (pair), Germanium Comps (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL Fusion, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM92, PCM70... Amps, Amps & More Amps.
  #72
Old 07-24-2019, 12:13 PM
JFreak's Avatar
JFreak JFreak is online now
Go.
HDX is supported on original cheesegraters which never had PCIe 3.0 and because HDX3 is supported even the PCIe 2.0 4x slots will have to be enough
Janne
  #73
Old 07-24-2019, 12:16 PM
JFreak's Avatar
All the tech talk in this thread is about taking maximum out of the new M.2 NVMe storage, which is bottlenecked by cheesegraters' PCIe 2.0 spec unless you know which card does the trick.
HDN/HDX has nothing to do with it. Regarding those cards, lowest common denominator is spec of worst PCIe slot you can find in a Mac.
Janne
  #74
Old 07-24-2019, 12:18 PM
arche3's Avatar
arche3 arche3 is offline
Also the mod from Sweden told me to use slot 3 for hdx. It helped in the past with 9073 errors in the cheese grater.
Sent from my SM-G975U using Tapatalk
  #75
Old 07-24-2019, 12:24 PM
JFreak's Avatar
Originally Posted by arche3 View Post
mod from Sweden
Chris? He knows what he's talking about
Janne
  #76
Old 07-24-2019, 12:37 PM
One last question and then I’m diving in.
Will I be able to install Mojave to one of the ssd drives on the dual switcher adapter without any extra setup or are there extra prep steps needed?
Thanks again for everyones input. I have read every thread on the subject, but as the years pass the pertinent information changes. Things that didn't work in the past now do. It’s hard to keep it all straight. So, thanks for not saying look it up for yourself, believe me I have.
  #77
Old 07-24-2019, 12:45 PM
arche3's Avatar
I think so. I was having computer freezes. My hdx was in slot 2. He (or another mod) told me to use slot 3. Fixed my issue. I have since then always used slot 3. I even put the eb7 pcie card in slot 3. For my hdx3 system.
  #78
Old 07-24-2019, 12:47 PM
arche3's Avatar
I think the installer disk image needs to be on a SATA internal disk for the update install. I'm researching updating to mojave as well with one of these m.2 setups.
  #79
Old 07-24-2019, 12:49 PM
JFreak's Avatar
... or USB
Janne
  #80
Old 07-24-2019, 01:02 PM
I have the Mojave installer on a USB stick. My plan was to install High Sierra on one of the SSD sticks and then boot from the USB boot stick Mojave installer to update the SSD drive to Mojave.
Mac Pro 2012 -should upgrade to Mojave? Zak7 macOS 5 06-04-2019 07:51 AM
Mojave? hanksinclair Artist Series 3 05-03-2019 03:19 PM
New 8th Gen i7 with NVMe m.2 SSD spock999 Pro Tools 2018 26 02-22-2018 11:47 PM
Bootable Thunderbolt case for NVMe drives (Samsung 950 etc) propower General Discussion 1 10-27-2016 04:11 PM
Intel SSD NVME/PCIe Porn Darryl Ramm General Discussion 0 04-03-2015 02:02 PM
