Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 07-12-2014, 02:49 AM
arjohe arjohe is offline
Default Mbox 2 new driver for Mavericks just doesn't work
I installed Mavericks 10.9.4 and after that downloaded latest avid 10.3.3 drivers from here:
http://avid.force.com/pkb/articles/e...-2-Pro-Drivers
Good news: Installing of driver is OK and system is restarted and after restart all lights in Mbox 2 turns on. Also when I start my PT 10 it works with my MBox 2 as well. But this doesn't bring much joy since....
Bad news: When I try play audio files or youtube Mbox 2 is doesn't recognized by the system and playback takes place via laptop speakers. Also if I disconnect Mbox 2 firewire and connect it back lights are not turn on anymore except that red power light on left top corner blinks. So now I can't use it with any device anymore. System restart at this point alone doesn't help instead I need to install MBox 2 drivers again and it doesn't solve the actual problem. Also if I try put my external MyBook Studio to same firewire hub with mbox 2 then whole system crashes and restarts automatically by saying first "system has crashed" with grey screen and then restarts. So together with MyBook in same firewire hub Mbox can not be used at all..
All this worked perfectly fine with my previous Lion OS. So definitely something is not working with new Mbox drivers with Mavericks. Any experiences, anyone? Any drivers or other system updates that Im still missing?
OR is the only way to solve this buying Mbox 3...
Old 07-16-2014, 06:41 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Mbox 2 new driver for Mavericks just doesn't work
Can you post your full system specs? Also, be sure not to hotplug any firewire device.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 07-16-2014, 11:20 PM
Originally Posted by JoelG View Post
Meanwhile I've managed to get Mbox 2 Pro work with driver 10.3.3 from Avid site but not as it should. By that I mean when I restart my computer Mbox 2 Pro is recognized automatically but every time when I unplug firewire and try to plug it again, Mbox 2 is not recognized anymore, also control panel says "Firmware: unknown" --> I have to restart again and then firmware is recognized and whole setup works.
Another error with current setup and 10.3.3 driver is that when I put system to sleep mode with Mbox 2 Pro connected and wake it up, then I get "system error" grey screen and computers restarts automatically.
My setup:
- MacBook Pro Late 2011, Mavericks 10.9.4, 16 gb RAM, Mbox 2 Pro connected with firewire 400-->800 adapter, MyBook Studio external drive connected via thunderbolt
- Pro Tools 11.1.3 and 10.3.0
- Firmware 10.3.3
Old 08-01-2014, 04:09 PM
Ed Douglas's Avatar
Ed Douglas Ed Douglas is offline
I get random kernel panics even when the system is sitting idle.
My setup:
MacBook Pro Late 2013, Mavericks 10.9.4, 16 gb RAM, Mbox 2 Pro connected via Thunderbolt to FW 800 adapter. Firewire 800-->800 to my HD, then FW 800 to 400 cable to Mbox2 Pro.
Software: ProTools 11.2
Hardware; Mbox 2 Pro
E.
Neotech Concepts
http://www.imdb.com/name/nm0235036/
! sonic gymnastics for the illusionary arts !
2022 Mac Studio Max 64GB / 1TB, macOSX 13.6.6, 2019 i9 MacBook Pro (15,3), macOSX 14.4.1, PT Ulti 2024.3.0, DAR 5.1, MDA Creator1.5, Rx10 Advanced, Ozone 10 Advanced, Kontakt 7, Soundminer v6.1Pro, Spanner 4, PaulXStretch,
EuControl 2023.11.0, Avid Control 2023.11.0, Avid S1, iPad Pros 12.9" gen 3 & gen 4, Apollo 8 Duo, UAD-2 Satellite Quad, Glyph 2TB tb3 NVMe SSD, x2 Glyph 2TB SSDs, x1 Glyph 4TB SSD, OWC tb3 Dock, OWC Thunderbay 8 62TB
Mbox 2 new driver for Mavericks ust doesn't work arjohe Pro Tools 11 1 07-12-2014 02:52 AM
Wave Driver doesn't seem to work at all... GiantMan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-21-2004 03:06 PM
ASIO driver for REASON doesn't work! catalyst718 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-12-2003 02:57 PM
ASIO driver for REASON doesn't work! catalyst718 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-12-2003 02:56 PM
New Midiman USB Driver doesn't work! Watch Out! KaiXXX 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 01-04-2002 06:07 AM
