Old 03-17-2020, 07:00 AM
JazzyJ JazzyJ is offline
Default EQ plugin that can take 'snapshot'?
Hi all, hoping someone can point me in the right direction.
I want to record an Acoustic guitar on two tracks in mono - trk1: with a Mic and trk2: with the guitar plugged in (piezo pickup)
What I'd like to do, is match the piezo sound to the mic sound - thus showing me the exact eq settings I'd need to adjust in order to make the piezo sound as close as possible to the mic version. (which will help be in a live situation, to know the basic eq settings I need to closely replicate the natural sound of the acoustic).
Is there an EQ plugin that can take a 'snapshot' of the eq frequencies of trk1 and then apply them to trk2.
Obviously I can do this by ear, but I'd like to know if something exists that can analyze trk1, and save the 'frequency sound' (so to speak) and apply to another track? Would Fabfilter Pro-Q 3 'EQ Match' be able to do something like that?
https://www.fabfilter.com/help/pro-q/using/eqmatch
Do know how clear I've made that, but hopefully someone will understand!
Hack Pro (4.2Ghz i7 Quad/16GB)
PT11 / OSX 10.8.5
TC Electronic Konnekt 24D
Old 03-17-2020, 07:14 AM
Jon_Atkinson Jon_Atkinson is offline
Default Re: EQ plugin that can take 'snapshot'?
It's a pretty tough thing to do.....
The best I've come across is Dynamic Spectrum Mapper, now called Pro Audio DSP DSM v3 (it's a bit of a mouthful..!)
Distributed by Plugin Alliance.
It's a plugin by Paul Frindle, previously of Sonnox. You could best describe it as an unlimited band compressor, which learns an EQ curve. They probably describe it better, but that's essentially what it does... Learns the shape of the sound and applies it to another.
I used it to fix a vocal I was sent, where half the track had been recorded with the mic pointing the wrong way round.... I honestly didn't think it was fixable with that level of comb filtering, but DSM did a great job.
They probably have a demo so you could check it out.
Whether that actually gives you the final sound you're looking for is another thing of course... There are obviously more factors in play than simple behaviour at each given frequency... But try DSM and see if it vaguely gets you to what you're after.
Mac Pro 2019 3.5GHz 8 Core 48GB RAM
OS 13.6.3
Protools Studio 2023.12
Antelope Orion 32, Vienna Ensemble Pro 5,
UAD Quad PCIe
Old 03-17-2020, 09:09 AM
Lynn Gräber Lynn Gräber is offline
The feature you are wanting is called "Match EQ". Pro Q 3 by Fabfilter can do this. I know there are others too.
Old 03-17-2020, 09:10 AM
There's a handful out there; personally I use FabFilter ProQ3's eq match function - fabulous all around eq too. Izotope Ozone also has a match feature as do others.
That said, matching a DI to a mic is a lot more than just EQ - UAD Woodworks does this in a plugin, though I don't think it allows custom IRs. In hardware, Fishman's Aura system does a good job of this, though making custom IRs is difficult. Tonedexter will do this and allow you to create your own IRs with your instrument/DI/mic combo.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 03-17-2020, 09:29 AM
DontLetMeDrown DontLetMeDrown is offline
Let’s address the source problem. The reason you’re even thinking about doing this is because acoustic piezo signals are garbage. To date, I still haven’t heard one that sounds better than a mic. You could buy ProQ3 to pull this off with EQ match, and that plugin IS worth every penny, but honestly, do yourself a favor and ditch the piezo signal and just use your mic. That’s going to give the best sonic results.
Old 03-17-2020, 09:31 AM
JFreak's Avatar
JFreak JFreak is online now
What he said.
If a tiny mic is inside guitar, it can never sound like you hear it outside guitar. Just place any mic towards 12th freth and it is guaranteed to sound much better than the internal one.
Janne
Old 03-17-2020, 09:57 AM
midnightrambler midnightrambler is offline
As much as I love the Fabfilter Q3, I have to admit there have been occasions when I've booted up Logic just so I can use the Match EQ on it. It just seems to be the best at doing that particular job.
Old 03-17-2020, 11:48 AM
Thanks everyone. Basically I'm looking to get detailed info about the Frequency curve and apply it live using the new SOURCE AUDIO PROGRAMMABLE EQ pedal when it comes out.
In a way, it's a different route to achieve what Tone Dexter does.
1. Record two simulaenous tracks - Mic & Piezo
2. Match the Piezo to the Mic
3. Note the frequencies, bands, db and 'Q' etc
4. Input them into a programmable parametric multi-band pedal to use live
PT11 / OSX 10.8.5
Old 03-17-2020, 05:34 PM
amagras amagras is offline
How does Tone Dexter matches his di?
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 03-18-2020, 08:45 AM
What you're trying to do is conceptually simple, and the suggested plugs will do what you want, but I think you'll find that a little 7 band eq pedal will do little to make a piezo DI sound like a mic - Woodworks/Aura/Tonedexter use a completely different process; they are *not* eqs.
Feed it the DI and a mic signal simultaneously and Tonedexter generates an IR to make the DI sound like the mic - it's not perfect (same as Fishman Aura or Woodworks), but it can surprisingly good when a pickup is absolutely the only way.
How to get Snapshot Automation? DrewHarrison Getting Started 3 08-18-2016 09:54 AM
Snapshot automation Audioartist Avid Pro Mixing General Discussion 2 08-01-2016 11:26 PM
Snapshot/plugin recall issue Realdon VENUE Live Sound Systems 5 05-01-2012 01:27 PM
Plugin set up "snapshot" filobus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-03-2007 06:26 AM
Snapshot automation neilbenezra Post - Surround - Video 1 06-14-2006 01:31 AM
