Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 04-02-2018, 09:40 AM
lolo-m lolo-m is offline
Default PT HD 11.3.2 doesn't see my 192 i/o
All is in the title, I'm running one HD i/o and a 192 i/o on a HDX card and since I upgraded into 11.3.2 both software and HD drivers, my 192 i/o disappeared while it seams to be reinitialised by PT when it starts. I haven't got any problem with my HD i/o, it's still there. I tried with the 192 only, 192 on port 1 and 2, and with the HD i/o as expansion or not. It's always the same, the 192i/o seams to initialise correctly and the sofware just ignore it...
Must I buy the Digilink licence to have it working again ?
Old 04-03-2018, 07:36 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: PT HD 11.3.2 doesn't see my 192 i/o
The digilink license is for 12.6HD and above.
How about defaulting the io's
whats the screen where you change the input level? +4 / -10 > I would muss around with that one also.
How about just hooking up the 192 and seeing if it is recognized by itself?
How about changing the digilink cable?
Daniel
Old 04-10-2018, 03:32 AM
I finally found out what was going wrong... I changed the option in/out cards of my 192 i/o witch was AN IN:ANOUT/DIGIT i/o to AN IN/AN OUT/AN IN/AN OUT. Digitest sees all the in/out but Protools doesn't understand what is plugged !!! That's completely stupid but now I put all my 192i/o in this configuration every thing is fine :
- SLOT1 AN IN
- SLOT2 AN OUT
- SLOT 3 DIGITAL i/o
- SLOT4 nothing.
Old 04-10-2018, 06:47 AM
YYR123's Avatar
Awesome thanks for reporting back !!!
It can help someone years down the road
Daniel
Why the 11R doesn't go to 11... :D Spidouz Eleven Rack 3 10-24-2010 03:38 PM
Shuffle doesn't shift volumes - copy & paste doesn't copy automation marcnyc Pro Tools TDM Systems (Mac) 2 03-12-2010 12:46 AM
It doesn't do something it used to davegibbon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-28-2008 09:17 PM
PT doesn't Doesn't Draw Some Waveforms savage Pro Tools TDM Systems (Mac) 3 01-10-2006 12:21 PM
PT 6.0.1 doesn't see my HUI!!! MMazurek Pro Tools TDM Systems (Mac) 0 06-21-2003 11:04 AM
