Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 01-17-2018, 12:45 PM
Default Re: mobo's with perfect HD/HDX compatibility? Win10 cubase multicore issue also with
As someone who has built and supports a lot of 8 core and up systems, I have never seen anything like this with Pro Tools. The problems seem to be more specific to their integration with Windows and Asio.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 01-17-2018, 01:27 PM
TOM@METRO's Avatar
I run HDX on an i7 3930k Hex Core in a Gigabyte x79 mobo. Runs all day every day with the latest Pro Tools builds. (Hyperthreading on)
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 01-17-2018, 03:22 PM
Brandonx1 Brandonx1 is offline
Originally Posted by TNM View Post
However, Cubase uses 2 threads per process so to speak so it's doubled.. which is why steinberg have a fix so that anyone with over 14 logical cores will use the fix and tell cubase not to use more than 14 (which in steinberg's case is using the maximum 28).
Maybe I'm slow but why can't you use a 14 core. If 28 threads is the limit, seems like a 14 core machine will work just fine.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 01-18-2018, 06:18 AM
TNM TNM is offline
You are not slow, you are simply misunderstanding.
Windows 10 no matter what edition can't use more than 32 processor threads in total for one instance of an app. But it reserves four for windows stuff, so that leaves 28.
Theoretically that would mean someone could buy a 14 core processor with hyperthreading, which would make it 28 logical cores, and that would work fine.
The bit you are missing is though that with Cubase, "Cubase schedules two MMCSS threads per CPU core whether real or virtual".
Therefore, an 8 core processor, is 16 logical cores, a ten core is 20 logical cores. But in cubase, that would be 32 for the 8 core, and 40 for the 10 core cause cubase uses 2 threads per core. Make sense?
This is why I am trying to find out if pro tools works the same way.
All those that use 6 cores processors, I appreciate your input but there's no need, really.. I know 6 cores will work, even if pro tools DOES have the "issue", as 6 cores is 12 logical cores, and in worse case if pro tools schedules two threads per core, then it's 24. Still well under the 28 limit.
It's only 8 cores and above I am worried about.
So specifically those with 8 core chips with hyperthreading ON, so, 16 logical cores, is what I need to know.
Cheers
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X.
Old 01-18-2018, 06:24 AM
TNM TNM is offline
With hyperthreading enabled? Pro tools native does use asio on windows.. I won't be able to go HD for a while after paying 6 grand for a computer, so i'll be subkect to Asio.
I found quite a lot of topics around the web last night of the issue in fact happening in PT, with one thread cpu spiking like crazy on large multicore systems, which is basically the problem I am concerned about.
I'll keep digging and I'll just ask avid, does pro tools schedule two mmcs threads per logical core. I'm sure someone there can answer me.
OTOH i am just tempted to buy the 8700K and be done with it, since i know it will work perfectly.. and in that case i'd definitely overclock to 4ghz permanently which is meant to be like baby steps for that processor.. and strong singe core performance is great for stuff like Kontakt.. Maybe that's the way to go.
I guess my lust for the 10 core comes from a POV in my mind where i am telling myself it would have enough power for me for the next decade, which it would. It was futureproofing more than anything.. I am sure that 6 cores will be enough.
So i will start asking some other important questions...
How are peeps using PT vanilla or PT HD native, finding low latency performance on windows 10?
  #16
Old 01-18-2018, 09:03 AM
YYR123's Avatar
YYR123 YYR123 is offline
Someone there most likely can, someone here most likely can't. They are not the same statements.
Daniel
  #17
Old 01-18-2018, 10:13 AM
TNM TNM is offline
yes but hearing from people with real world experience with big multicore setups on windows 10 is still very worthwhile info and what i *really* need when it comes down to it.
Unless i am misunderstanding, so far i am only getting reports from either HDX users or 6 core users..
i really need to hear from someone using either hd native or vanilla and is running 8 or more hyper threaded cores, so 16 logical cores or more.
cheers
  #18
Old 01-18-2018, 10:18 AM
YYR123's Avatar
What I meant was...
You said I’ll ask Avid. But Avid doesn’t hang out here, just users. Especially anyone with Avid who would be able to parse down the question (All Respect Jeffro)
So if you want to ask Avid that’s fine - I just didn’t want you to think that you would be to get ahold of them here.
Daniel
  #19
Old 01-18-2018, 11:13 AM
People around here complain about the "center core" spiking on 4 core systems and every other system and the same issue on Mac/OSX. There is ways, plugins, and system problems that force this to happen that have nothing to do with what you are concerned about. As I said, I do this all the time, far more than anyone else here and I have never seen anything like it. Yes hyperthreading is enabled.
The 8700k runs at 4.7Ghz without overclocking. Makes 0 sense to run it at 4Ghz.
Latency is fine on Windows. Just like Macs, your audio interface driver is the biggest determining factor. Your posts seriously read like someone who is trying to talk far to high above their paygrade....
pro-tools-pc.com
Intel I7 9900k
Win 10
  #20
Old 01-18-2018, 11:23 AM
TNM TNM is offline
What I meant was...
oh yeah i got what you were saying, 100%, and thank you kindly!
I just meant that it's still worthwhile to get that other bit of info from users, as it is for me to start an official support request with avid.
No matter what they say, real world results are still as important to hear from others, if not more so!
I think we are on the same page. Cheers :)
Issue with P55 Mobo and i5 CPU bgugler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 01-12-2010 06:17 AM
cubase compatibility sirlochness 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-09-2007 09:04 AM
Mobo Compatibility - Gigabyte K8N Pro-SLI?? CassidyGT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-12-2005 04:26 PM
mobo compatibility rems 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-26-2001 06:13 AM
MTC / Compatibility with Cubase VST Jose San Miguel Pro Tools TDM Systems (Win) 1 11-12-1998 03:46 AM
