  #171
Old 11-20-2017, 06:51 AM
innenhofstudios innenhofstudios is offline
Default Re: Automation AppleScripts for Pro Tools (Mac)
and now next step is to automatically excecute a 1fps crossfade at begin and end of the Rendering... This is going to be tricky
www.innenhofstudios.at
  #172
Old 11-23-2017, 12:31 AM
Oliver M Oliver M is online now
Originally Posted by innenhofstudios View Post
Hahaha. My Mistake. Nearly none.. only Toggle Mix/Edit which is a shortcut already for decades
Well, my script to toggle Mix/Edit Window was a workaround for a bug in Pro Tools where the default Pro Tools shortcut to toggle Edit and Mix Window didn't work on German and other foreign keyboards without numeric keypad.
I guess this bug was fixed? Haven’t checked for a while.
  #173
Old 11-23-2017, 01:24 AM
yes it does
(Cmd) + (=)
  #174
Old 11-06-2018, 11:21 AM
Hi Oliver,
I wonder if there is also a script for opening Tracks Presets ? Tracks are already implemented in vol2... but opening Presets by name ? any idea ?
Best René
  #175
Old 11-12-2018, 01:50 AM
Hi Oliver,
Best René
Yes.
But such a script only works if the name and the location of the Track Preset is known. Thus it needs to be a personalized script as the path to the Track Preset can vary.
  #176
Old 01-17-2019, 12:14 PM
johannes1 johannes1 is offline
this thread is very inspiring. thanks.
i just wondering how to select audiosuite-plugin presets using applescript.
so far i managed to click on the "preset" popup window of the rx declicker but didnt figure out how to click on "item 1" which is named "medium2.4"…
this is what i have for now. appreciate any hint. thanks
tell application "System Events"
tell process "Pro Tools"
tell window "Audio Suite: RX 7 De-click"
click pop up button 7
end tell
end tell
end tell
  #177
Old 01-17-2019, 12:57 PM
its2loud its2loud is offline
Try this
Keystroke “the name of your preset”. For example (keystroke “John declick”
Delay 0.3
Key code 36
end tell
end tell
end tell
  #178
Old 01-17-2019, 01:41 PM
thanks for your quick reply!
yes it works, but it takes about 5 seconds from opening preset popup to the selection of the item…
  #179
Old 01-17-2019, 01:45 PM
Yeah. I see that. I think there’s a system delay for the “click” command in the script.
I’ll try and get a workaround for that. I believe the script is waiting for a system response hence the delay.
I’m open to suggestions.
  #180
Old 01-17-2019, 01:56 PM
just found out that oliver already mentioned that delay in this thread.
Originally Posted by Oliver M View Post
From there you can navigate with arrow keys but be prepared to deal with a 6 second delay after the Track List pop-up menu has opened. Thats a known issue with several Pro Tools menues and AppleScript. You can workaround this by using cliclick to perform the click. Cliclick has been mentioned several times within this thread.
but i have no clue how i can use cliclick for my purpose. i guess, instead of referencing the preset popup window by its name i will automate clicks by coordinates?
Pro Tools 12 Trim Automation [email protected] Pro Tools 12 2 08-16-2015 04:25 AM
Pro Tools 11.2.1 Automation Bug?! Gneal550 Pro Tools 11 1 11-22-2014 01:15 PM
GRM tools automation bug? D'Animation Pro Tools TDM Systems (Mac) 6 10-08-2014 08:21 AM
scripting Pro Tools; automation Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 10-01-2004 12:38 PM
AppleScripts and other Macros for PT Bergeron Tips & Tricks 1 11-15-1999 06:55 PM
