Old 05-18-2017, 03:40 AM
J-S-Q J-S-Q is offline
Default Re: PT does not follow S3 Banking when in VCA Master Mode
Originally Posted by KeyplayerG View Post
Is this problem PT specific, or does this happen with Nuendo/Cubase, Logic, DP, etc.
This issue does not affect Cubase/Nuendo because:
A) There is no VCA spill feature with Cubase/Nuendo.
B) The mixer/arrange page do not follow banking on the S3 anyway (at least not until you actually select a channel on the S3).
Old 05-18-2017, 09:55 AM
EddieJones's Avatar
Just picking this up. I think what should happen when spilling a VCA is either it should not scroll PT at all or scroll to the first slave/group track?
One might be easier in software to implement but which do you guys think would be best ?
Old 05-18-2017, 11:35 AM
yoerik roevens yoerik roevens is offline
It should definitely scroll to the first spilled track (first track of the spilled VCA).
Even if there's fixed tracks on the first faders in the current layout!
(let's say you want your monitor level or master fader to sit on channel 1 forever, which would mean the first spilled track will be on fader 2 or higher)
That's the only way to quickly navigate large sessions. Would there be any reason why PT would jump to other tracks than the ones you're spilling?
As for 'not scrolling at all' that's exactly what happens if you turn the feature of.
For those who want to enable/disable this frequently, it would be great if the the 'edit/mix windows follows...' prefs are added to the Eucon commands, so you can assign it a softkey (which I find very convenient for toggling trim mode on sends e.g.)
Old 05-19-2017, 05:12 PM
KeyplayerG's Avatar
KeyplayerG KeyplayerG is offline
Nuendo has VCA Spill. It's just called the "Expand" function in Nuage.
Old 05-20-2017, 04:50 PM
ha2dorff ha2dorff is offline
My vote: Scroll to the first
Old 05-21-2017, 08:09 AM
Basket Basket is offline
YES!
Old 05-22-2017, 11:15 AM
Cubase also effectively has VCA spill WITHIN THE SOFTWARE (It's a feature called "Show Channels connected to First Selected Channel). The issue is that the spill is not reflected on the control surface. This is the case in Cubase and as far as I'm aware it's the case in Nuendo too.
Old 05-23-2017, 05:09 AM
bobbyguelz bobbyguelz is offline
I agree as well Eddie... I think it'd be most useful to have it scroll to the first track in the slaved group. This would be so nice to have implemented to make using VCA's more visually appealing to use in post and music.
Old 11-10-2017, 09:17 AM
yop22 yop22 is offline
Hi Jonah,
Has eucon 3.7 fixed the s3 vca spill scrolling issue for you ?
Thanks
Jerome
Win 10 pro, Asus Rog Maximus, i9 [email protected], 64GB
PTHD native, 2x96IO, SSL Delta Link, S3
Old 11-09-2018, 01:49 PM
reichman's Avatar
reichman reichman is online now
I need scroll to the first slave too!
VCA spill exists to simplify big track counts. Often I need to see where I am in the edit window in order to grab the right slave fader. Thanks Eddie!
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Mixed mode LAYOUT / BANKING ? kava Avid S4/S6 8 07-08-2015 08:47 AM
Pro Tools on screen mix windows follow banking . priorytools Artist Series 0 02-21-2015 10:13 AM
automation mode buttons/C8 channels follow track-selection automatically clusterer ProControl, Control|24, Command|8 2 11-24-2009 03:16 PM
banking through flip mode ec123 ProControl, Control|24, Command|8 1 01-02-2008 07:34 PM
aux won't follow master fade automation 001fran 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-29-2002 01:34 PM
