Old 01-10-2019, 02:14 PM
Default Re: Too much GPU usage
Originally Posted by Fernando Antunes View Post
I tried to open PT in low resolution mode and it seemed to help.
Maybe this issue is related to:
1 - pro tools graphic optimization (since the garageband's graphics works fine);
2 - macbook's cooling system;
I'm wandering if an eGPU can reduce even more the heat, since the CPU and RAM are running fine with a lot of headroom.
Thank you guys!
I'd give the latter a try if you can borrow one; after all why spend the money and find out it doesn't solve the issue?
Jack
QAPLA!
Old 01-17-2020, 04:09 PM
LukeHoward LukeHoward is offline
Following up on this. Pro Tools driving a 4K monitor slams my RX480 at 100% GPU usage; setting it to open in low resolution fixes this. I wonder if it is an issue that Avid can and will address, or whether it just needs a beefier GPU.
https://lukehoward.com/
Old 01-18-2020, 12:41 AM
the.engineer the.engineer is offline
I had an AMD R9 280X which has 3GB of memory and my graphics meter was being slammed.
Changed up to an RX580 (with the downside of having no boot screen) and now have no issues.
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire)
macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
Old 01-18-2020, 12:47 AM
Interesting. I'm running a RX480 now and GPU is getting slammed. I am thinking of upgrading to the new Mac Pro and am not sure whether to get the RX580 or wait for the W5700X.
Is anyone comfortably driving a 3840X2160 monitor with Pro Tools? And if so, with which GPU?
Real CPU Usage vs. Pro Tools System Usage Window tbonesteak4dinner Pro Tools 11 19 02-21-2019 08:04 PM
CPU usage error?! System usage 2%... pascalmowla Pro Tools 12 3 03-10-2016 12:00 PM
What would normal disk usage considered to be in the usage window? Digitopian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-08-2009 09:50 PM
Help understanding CPU Usage, RAM, Disk Usage... Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 02-03-2006 07:41 PM
HTDM not showing CPU usage in the system usage Brandonx1 Pro Tools TDM Systems (Win) 3 12-19-2004 09:45 AM
