Old 07-06-2014, 10:43 AM
asterix2k10 asterix2k10 is offline
Default Please Help: can't open OMF files in Pro Tools 11
Could not complete the Open Session... command because Assertion in "/Volumes/Development/126373/ProTools/App/MacBuild/../PtSess/PtAAF/PtSess_Iop.cpp", line 169.
Any suggestions on what to try?
Thanks.
Old 07-06-2014, 10:51 AM
Nate Hoffman Nate Hoffman is offline
Default Re: Please Help: can't open OMF files in Pro Tools 11
What version of 11? The first release was useless for reading OMFs. With the latest version, if 11 can't open it then 10 can't either in my experience. In those cases, I open and re-export them in Adobe Audition.
Nate Hoffman
www.blufirestudios.com
Old 07-06-2014, 01:32 PM
CygnusX-1Bk2 CygnusX-1Bk2 is offline
Will it work with Import Session Data? That's how I get AAF files imported.
I will choose,
Freewill
http://jimdiazaudio.com/
Old 07-06-2014, 02:06 PM
No, same problem with Import Session Data.
I used the latest PT Prefs to delete everything, but it didn't work. I also repaired permissions on my mac using disk utility, and also repaired the audio drive. I am on the latest Pro Tools 11.2 HD. Same issue still no matter what I try. I asked the editor to re-export the OMF's, she did that but this didn't make a difference. Any ideas?
Old 07-06-2014, 02:17 PM
Seriously - Adobe Audition. If you don't own it, I think there's a free trial. I have always been able to open problem OMFs in Audition and then export as an OMF that Pro Tools can read.
Nate Hoffman
Old 07-06-2014, 02:43 PM
Thanks. I WAS able to open by importing into Logic X, exporting as AAF and importing that in PT. Problem is, I am having issues with many of the audio files being out of sync. I will look into Adobe Audition.
Old 07-06-2014, 02:58 PM
Pete Gates Pete Gates is offline
I got an OMF exported from Premiere (latest version) the other day that wouldn't import properly into 11.2 but would (with two warnings) import at least 99% correctly into 10.3.9 so 11 is still not as good with OMFs as 10 was.
Pete
Old 07-06-2014, 05:06 PM
Pete
Good to know. I tried PT 10 a few times with no luck, so my default became Audition. I just assumed that 11 was as good as 10.
Nate Hoffman
Old 09-10-2014, 04:43 AM
fork-media fork-media is offline
any update on this?
I have been opening many OMF with 10 - but my first 10 as a HD as the assertion failure,,
i tried latest version of 11 in mavericks, also failed,
I tried on my neighbours PT9 system... also failed
the file opens in DP7 but lots and lots of out of sync an repeated files ( actually thats common in DP - actually I thats how I got sucked into protools - becos I was using it to "reconform" OMF for DP...
the best software ever was fairlight's AV transfer -= but its PC only and quite pricey!
sadly i no longer have access to it!
2018 i7 3.6 GHz 6 core mac mini running monterey 12.6.2 - 32Gig RAM 512 Gb SSD drive
Focusrite Saffire PRO 40
Ultimate 2022 10 / HD Avid MC Mix / MC Control
Can't open files from Pro Tools 8 HD WITH PT10 csrMark Pro Tools 10 2 01-12-2014 08:38 PM
HELP!!! I can't open my Pro Tools files, I keep getting errors. Possible 10.3.3 bug? rockguitarist1255 Pro Tools 10 4 12-30-2012 02:28 PM
Can ProTools 7.x open Pro Tools 9 files? marcnyc General Discussion 3 08-04-2011 01:49 PM
Pro Tools 8 open 6.9.2 files HELP audioboo Pro Tools M-Powered (Win) 2 09-26-2010 02:34 PM
Can't open SD2 files in Pro Tools Osmin Camero Pro Tools M-Powered (Mac) 3 05-20-2007 11:10 AM
