  #61
Old 06-06-2019, 05:51 PM
mattrixx mattrixx is offline
Default Re: 2019.5 OLED not responding properly
Hi Eddie,
I did not check that. (I'll go through the process again).
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
  #62
Old 06-06-2019, 06:15 PM
Ok, so yes, when running 3.6.1 I did see all the Eucon midi ports as expected. However, just installing the 19.5.1 update over the top, the ports are no longer there.
Matt McKenzie-Smith
mattrixx.net
  #63
Old 06-06-2019, 07:26 PM
Sean Bombz Sean Bombz is offline
I assume you’re running pro tools at the same time and therefore not locking EUCON to total mix or pro tools so you can switch between programs.
When I got Mackie Control to work with studio one all was well until I opened safari. Studio one wasn’t locked to EUCON and s3 unfocused. When I focused studio one s3 never focused. I had to restart EUCON and lock studio one to EUCON. It all worked after that.
So I wonder if there is bug disconnecting midi ports
Sean Bombz
Mac Pro late 2013 3.5GHZ 6 core 64g ram
Mojave 10.14.5
Pro tools 2019.5
Apollo x 16
Apollo 16 mk2
Apollo twin mk2
Avid S3
PT Dock
PT control (iPad)
eucon 2019.5.1
  #64
Old 06-06-2019, 07:31 PM
Hi Sean,
Yes, under 3.6.1 I managed to get the ports back and were visible in Totalmix. It didn't seem to work all that well (Of course the iPad app wasn't compatible with that version of Eucon and the S3 didn't seem to respond properly. But never the less, the ports were available.
However, the update to 19.5.1 immediately after, saw the midi ports for Eucon disappear once again. ie They're not any where to be seen.
Cheers
Matt McKenzie-Smith
mattrixx.net
OLED brightness RogerPaolo Avid S1, S3, Dock and Control App 21 01-26-2022 08:26 AM
OLED eq graph Macsearcher Avid S1, S3, Dock and Control App 9 10-26-2018 02:02 PM
Artist Mix - text on OLED is cut off at the top Bul Artist Series 2 10-20-2012 09:40 AM
mc mix second channel 's OLED missing ! klyg Artist Series 2 10-10-2011 10:14 AM
