Old 04-02-2018, 08:19 AM
Vultage Vultage is offline
Default Track Presets not showing up. [SOLVED]
I've been using the track presets feature for quite some time. Never had a problem with it. Save As Template, then choose location,. Created "Track Presets" Folder...
The other day, when I went to add a preset track, they were not showing up in the list of Track types. I tried to save new track presets, however it did not change anything.
I just installed the latest PTs update, Now, it IS showing Track Presets at the bottom of the track type list, with an arrow, as it should, however, it is greyed out, and I cannot select it. I've tried again to save some new track presets,. but nothing has changed.
Has anyone else ran into this problem?
Old 04-02-2018, 11:01 AM
ChuckS ChuckS is offline
Default Re: Track Presets not showing up.
Maybe help here: http://duc.avid.com/showthread.php?t=396604
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 04-02-2018, 11:38 AM
Thanks! I read through those 3 pages,. however, I've never used the workspace, so, I'm not sure what they are talking about when they mention that.
I'm just looking for Track Presets to be in the "Create New Track" dialog box,. under Track Type dropdown.
Old 04-02-2018, 12:48 PM
Just thought it might have something to do with that MiscSettings file that caused problems in the Workspace. Try deleting the MiscSettings file and restarting PT to see if they come back. You can check in your user Documents\Pro Tools folder to make sure they're still there. Also check Preferences to make sure User Media and Settings locations are correct.
Old 04-02-2018, 12:52 PM
ok,. right on,,. I'll try that! I've checked that the files are there, and my media settings are correct. :)
Old 04-02-2018, 01:00 PM
yeah,.. unfort no luck with deleting the miscsettings file,. as well,. tried to save track template again,. which still didn't help,...
Is kind of annoying,. as I use that feature on a very regular basis!
Old 04-02-2018, 01:14 PM
Try opening the Workspace and see if they appear there. Don't think that would help your issue, but at least rule out something tied to Workspace.
Old 04-02-2018, 01:45 PM
Ok,. nice,.. I didn't know that there was a Track Presets shortcut in the Workspace,. I've not used Workspaces,. always have just used Windows Explorer,. but I can see how Workspace would be a better option.
Anyhow,. Track Presets are NOT showing in the Workspace! That may help to sort this out?
Now,. I want to note,.. My User Media folders are all on my E: Drive. That is where Track Presets have always been as well, when they worked. After this issue, I've tried also saving Presets to the User/Documents/Pro Tools folder. Also tried adding sub folders, none of this worked.
Old 04-02-2018, 03:13 PM
Were you using the save tracks as template work around and thinking those will show up in Track Presets? OTT, moving stuff can cause issues - don't have any other suggestions.
Old 04-02-2018, 03:53 PM
Yes,. I didn't know it was a workaround,. just thought that was how you were supposed to do it,.. lol. Didn't know there was another way. However, it did work before,. PT12, prob 2 updates ago.
Anyhow,. thank you very much for trying to help, and giving me ideas to try!!!
Track Presets not showing in Workspace [solved] thanos4 Pro Tools 2018 26 10-17-2018 01:49 PM
Track Presets [solved] jkeefauver Pro Tools 12 9 01-29-2018 09:36 AM
Presets Not Showing Up americanslidol Pro Tools 11 5 10-07-2015 04:24 PM
at times plugin presets not showing digidesigner VENUE Live Sound Systems 2 11-29-2009 12:33 PM
Plugins presets not showing francois Pro Tools TDM Systems (Mac) 1 09-15-2005 09:06 AM
