Poor graphics PT 2018.4 on Windows 10 Pro
I am very disappointed in respect to the looks of PT2018.4 on Windows 10 Pro, is this normal that fonts etc are a little blurry compared to PT on Mac?
Gaston PROBLEM SOLVED 1) Right click on the Pro Tools app (in program folder) 2) Select Compatibility Tab 3) Enable/Tick "Override high DPI scaling behaviour. Last edited by Gaston69; 07-07-2018 at 05:27 PM. Reason: Problem solved |
Re: Poor graphics PT 2018.4 on Windows 10 Pro
Are you using the same monitor? Have you checked your resolution? I would guess you are also using the built in video card on your motherboard and not a dedicated graphics card? All these can affect this unfortunately.
Check your Display Settings for scaling and monitor resolution options.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
I am having:
HP Z420 E5-2670 Workstation with a Quadro K2000 NVIDIA card, 2560x1440 resolution |
How do you have the monitor connected? VGA, DVI (is it Dual-Link), Display Port?
And what is the resolution of the monitor? And are you sure the monitor is using the NVidia card and not the Intel built-in (if it's available)?
The monitor as a Dell Ultrasharp U2515 and works fine, the rest of the graphics on Windows look OK; it is just PT2018 that does not look as good as on my Mac, first I thought I was forgot my reading glasses ;-(
You are using an old cheap video card.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
You are using an older cheap video card.
PROBLEM SOLVED
1) Right click on the Pro Tools app (in program folder) 2) Select Compatibility Tab 3) Enable/Tick "Override high DPI scaling behaviour. |
2018.4 + Windows 7: Won't even let me install :( | DontLetMeDrown | Pro Tools 2018 | 16 | 01-04-2019 05:55 PM |
Windows Graphics Card | Media Man | Pro Tools HDX & HD Native Systems (Win) | 1 | 03-31-2016 05:00 PM |
Graphics weirdness in PT windows--anybody else seen this? | bashville | Pro Tools TDM Systems (Mac) | 4 | 03-31-2007 12:02 PM |
Why do 002 have so poor windows support? | juanit0 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-24-2004 01:26 PM |
Graphics trouble with mbox + xp, poor perfomance c/w PTfree on win98 | phil bax | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-12-2002 02:00 PM |
