Old 03-16-2001, 07:18 AM
gregfrey gregfrey is offline
Default Screen Freezing in PT 5.1
I just installed 5.1. I have a 9600 with a NewerTech G3 card, 256 Meg of Ram, and OS 9. Now, when using PT, in the edit window, every now and then my screen will freeze for about a second. It happens in playback and record. There is no interruption of sound. Any ideas as to how to solve this? Is it a CPU usage or H/W or disk cache settings issue? Or is my video card not up to handling 5.1?
Thanks
Greg Frey
Old 03-16-2001, 11:23 AM
DaveCarlock DaveCarlock is offline
Default Re: Screen Freezing in PT 5.1
[QUOTE]Originally posted by gregfrey:
Thanks
Greg Frey
[/QUOTE
I'm noticing this too on a G4/350 with over 300 MB RAM. Perhaps this is another symptom of whatever is making my MIDI slop occur on 3 MIDI tracks--Kick, Snare, & Hat?
Old 03-17-2001, 11:48 AM
Gremlin Gremlin is offline
I have noticed this as well, but it seems to happen only when "Sherlock" is running in the background. Quit Sherlock....freezes go away.
Old 03-18-2001, 07:56 PM
clutch clutch is offline
check out Farmer Daves's problem
(http://duc/digidesign.com/ubb/forum16/html/006897.html) - seem similar? I am working with FD to try to rectify.
Digi are aware of this problem and are working on it apparently.
If you come across an answer let us know!
He used to cut the grass...he was a very nice boy...
Old 03-19-2001, 07:52 AM
DigiTechSupt's Avatar
-If installed, Norton Utilities can also cause this behavior. Disable all Norton extensions such as FileSaver, ScanDisk and Disk Light.
-In addition, make sure the Energy Saver Control Panel is installed and set to "Never."
-It is also highly recommended that you reduce the Disk Cache in the Memory Control Panel to 512k.
Brent
[This message has been edited by DigiTechSupt (edited March 19, 2001).]
Avid Audio Tech Support
Support FAQ
avid media composer 6.5 freezing source screen debojam Getting Started 0 02-12-2014 12:35 AM
Pro tools SLOW, and Freezing then continuing, then freezing again DJX-RAY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-09-2011 08:52 AM
Freezing at the start up screen! LovesXMusicX General Discussion 1 08-16-2010 07:52 AM
melodyne screen freezing/chopping prestonrmail 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-10-2009 03:09 PM
Screen freezing (on and then off) Mr Layz Pro Tools M-Powered (Win) 2 05-16-2006 02:15 PM
