Old 01-31-2023, 03:13 PM
bing181 bing181 is offline
Default Delay Compensation Limit + Ozone?
I'm trying to get a series of tracks out of Pro Tools as loops. These will then be fired off as part of a live project.
But ... I'm running up against the dreaded delay compensation limit in Pro Tools. I'm using a couple of plugins on my master bus, one of which is the dreaded Ozone which takes 18K (or so) samples - but the Pro Tools delay comp limit in my config is around 16K samples. The end result is a blank space at the beginning of each of my loops, making them unusable.
Short of printing back into my session, which would be a pain on multiple levels, is there any workaround here?
Doing my head in.
Thanks in advance.
Old 02-01-2023, 07:58 AM
Default Re: Delay Compensation Limit + Ozone?
Lower buffer settings? Audiosuite for the Ozone processing? Be sure to bypass all unused modules in Ozone.
http://www.richbreen.com
Aux Routing Weirdness / Ping-pong Delay Messes Up Delay Compensation MKZ Pro Tools 2018 3 02-10-2024 10:31 AM
Delay Compensation Limit woes alexthemusicbloke Pro Tools 38 03-20-2023 02:08 PM
delay compensation problem involving EZ drummer, routed midi, and Ozone soybalm Windows 2 03-02-2013 09:34 AM
Protools 9 delay compensation limit lachlan Pro Tools 9 109 12-11-2012 01:57 AM
Delay Compensation Limit Removal lachlan Pro Tools 9 36 02-23-2011 07:33 AM
