Old 10-06-2017, 07:44 AM
EddieJones's Avatar
Default Re: New dock solo button lower then mute button
Sorry, I didn't hear back. I think you have done the right thing, let me know what they say.
Old 10-07-2017, 10:31 AM
Anthony_Anz Anthony_Anz is offline
Originally Posted by Sean Bombz View Post
Thanks Anthony . I’ve contacted my dealer .
Ya, I think that's the best thing. There is no down side and you'll know for sure if your original unit was not right. Things happen. production is never 100%.
Old 10-07-2017, 01:23 PM
BTW this a not uncommon type of problem with silicone rubber membrane based switches. There will be an flexible elastic membrane/sheet with "spring" dimples on it where the buttons are, that sheet goes between the button top and a backing PCB. The dimples give the switch it's "spring" and holds it open electrically contacts on the inside back of the dimples close the switch contacts in the PCB electrically or capacitively when pushed. The button may be painted on or bonded to be membrane or loose, but these problems can happen when things don't line up, especially if the membrane is not properly in alignment grooves or pins on the backing PCB assembly. Often easy to fix by just reassembling the parts. But clearly here the dealer and Avid should be looking after you.
Old 10-11-2017, 07:11 PM
Sean Bombz Sean Bombz is offline
Just letting everyone know that AVID have indeed taken care of me . Received my replacement dock today . Mute button is normal . Thanks Eddie for your help and thanks Anthony and Darryl for your replies .
Sean Bombz
Mac Pro late 2013 3.5GHZ 6 core 64g ram
Mojave 10.14.5
Pro tools 2019.5
Apollo x 16
Apollo 16 mk2
Apollo twin mk2
Avid S3
PT Dock
PT control (iPad)
eucon 2019.5.1
Old 10-12-2017, 06:05 AM
Awesome, glad to hear it! yea, I figured there was something -- not quite right with that one. =)
How to replace mute button Zep Dude ProControl, Control|24, Command|8 1 03-12-2013 02:03 PM
MIDI mute button - what does it do? (PT 9.0.3) iain_m Pro Tools 9 11 08-16-2011 01:57 PM
mute button keeps clicking on chal7ds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-28-2006 08:57 PM
Mute button won't release mihaka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-08-2005 06:34 PM
002 MUTE BUTTON micah421 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-20-2003 05:45 PM
