adat bridge w/ nubus protools?
so this is kinda funny....
i'm going to pick up a complete protools 4 (i guess?) nubus TDM system tommorow night for basically nothing....they just want it out of their facility..... it's loaded with plugins i guess and i figure that there may be something in there i would'nt mind using every now and again so my question is: Is it possible to use an Adat Bridge io to get audio in and out digitally with this nubus stuff? It's coming with an 882 which has 2channels of spdif 24bit i guess, but it could be nice to have more than 2channels Have I given enough info? thanks so much, adam |
Re: adat bridge w/ nubus protools?
Memory is a little foggy, but I think you'd need the original ADAT IO, which would add another 8 channels assuming you had an ADAT to use for the converters. I did this for a while when I got my first Digi rig, but there were some issues with pops and clicks that I never solved. I was using the 882 as well. I may be wrong, but I think that ADAT IO will only do 16 bit.
Recording artist/Engineer/Producer Waves beta tester |
man....
i was hoping to just set this thing up as an external fxprocessor and just run adat back and fourth from/to my rosetta800 i have hooked up as my main IO for the HD rig..... i guess ill just have to hook it up and give it a go! project for tommorow night? i think so... |
ADAT BRIDGE interface with a PTIII NUBUS? | ppuskari2 | Digidesign Hardware & Software | 0 | 06-22-2006 12:53 PM |
USD=MTP/AV=2 ADAT bridge,s/dump adats 2 protools | funkin | Tips & Tricks | 3 | 04-02-2004 10:30 PM |
Is Adat Bridge Nubus Compatable? | Tex Tiles | Pro Tools TDM Systems (Mac) | 2 | 03-31-2002 01:01 PM |
ADATs w/ BRC Thru ADAT Bridge to ProTools | Howardk | Pro Tools TDM Systems (Mac) | 7 | 10-11-2000 05:15 AM |
PT III Nubus to 03D via Adat Bridge | speranza | Pro Tools TDM Systems (Mac) | 1 | 03-16-2000 12:26 AM |
