Old 12-08-2017, 02:56 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Is it worth me getting an Eleven Rack?
Originally Posted by Suddenly Clear View Post
In that case I'll keep my Fast Track, which might still prove useful for recording in some circumstances. My problem with the integrated sound card lies with the fact I have no physical volume dial, or switch off, where I can kill the sound quickly.
Thank you for your input.
While you CAN use the Eleven Rack for all audio, it can be an issue. The multi-device drivers don't always work properly. Sometimes your PC can lock the driver and cause issues when using Pro Tools.
That's why most of us on the Windows side suggest keeping your interface for recording, and your integrated sound card for PC audio.
If all you want is a control, get a computer keyboard with volume controls on it. I couldn't live without that control. Many of the Microsoft of Logitech keyboards have these controls, vol. up, vol. down, and mute.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 12-09-2017, 10:57 AM
Suddenly Clear Suddenly Clear is offline
Thank you, Benoni, that's really helpful.
I'm getting the Eleven Rack! Thanks all for your advice, much appreciated.
Old 12-09-2017, 07:00 PM
Pingafuego Pingafuego is offline
What I'd like to know before I buy an Eleven Rack is whether I could easily use it for general computer audio activities, like listening to music, You Tube, whatever?
As trivial as it might seem, it's important when I'm using my computer for general purposes as well as recording...
Thanks
I use it as my only recording interface, and use it to listen to music, youtube, etc, without any problem. But I use a MacBook Pro.
All I have to do is turn it on, Mac OS recognizes it, turn on my monitors (or plug in a headphone) and I control all computer audio with Eleven Rack's volume dial. It's really very easy.
Old 12-10-2017, 06:34 AM
Jay_uk Jay_uk is offline
Interesting little device, jay_uk, thanks!
You can also hook it up to the headphone socket of your Mac/PC with a Toslink cable to get digital conversion. For those times when you are not firing up the Eleven Rack.
Old 12-10-2017, 01:14 PM
Benoni's Avatar
The way OSX handles multi-client drivers is different than Windows though. It's not that Windows "can't do it", it comes down to how the drivers are written, and how the DAW utilizes the driver. The Komplete Audio 6 for example does great on Windows as a multi-client host. But for the Eleven Rack and other Avid interfaces, I have had problems trying to use them as the main interface. Sometimes they lock up, sometimes your session gets stamped with the wrong sample rate because the PC and Pro Tools are using two different settings, and some apps will not used the Eleven Rack driver as an audio output source.
The suggestions from us to keep your interface as your DAW audio source and use your integrated audio for PC sound do not come from a place of "that's improper" or "it can't be done". It's just about giving the user the best possible experience with the least amount of issues.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 12-12-2017, 11:09 AM
One concern with the set up would be how to route it, virtually and physically. At the moment my Fast Track C400 deals with all the audio and outputs by 1/4 jack cables to the monitors. How would I record with the Eleven Rack and output via the integrated audio or the C400?
I appreciate everyone's contritions in this thread.
Old 12-12-2017, 11:23 AM
Southsidemusic's Avatar
Just dont use the c400 interface. It is not great and the eleven rack is a lot better imho of course. I have a c600 here which someone left or forgot and it is horrid. I will give it away for free!!
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-13-2017, 01:19 PM
I'm actually planning on giving my C400 away to someone for Christmas. I have an old Delta 66 as well, which I might put back inside my PC.
Anyway, the big news is my personal Christmas present, the Eleven Rack, has been ordered. So I guess, I'll be dropping in on this friendly forum quite a bit...
Old 12-13-2017, 01:24 PM
Looking forward to hear your progress and thoughts on the Eleven Rack as it is a really awesome piece of gear
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 12-15-2017, 10:00 AM
Another question: I have many unfinished projects with recordings made using my Fast Track C400 (which I'm giving away), will there be a noticeable difference to the detriment of the song to mix those with Eleven Rack recordings? Would it be possible and worth routing these old recordings though the Eleven Rack and back into Pro Tools?
Thanks
Check out the Eleven Rack Presets Matched for Eleven plugins by Pro Tools Expert! Justin1524 Eleven Rack 0 11-27-2015 02:53 PM
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? Rongpat Eleven Rack 8 02-11-2014 07:42 AM
Is the eleven rack worth the money !! Darren01 Eleven Rack 23 11-10-2013 03:17 AM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
