Old 12-12-2017, 09:09 AM
jaaphelmus jaaphelmus is offline
Default Could not complete the Open Session
Hello,
Could someone help me with the following error I get when trying to open a recent session:
Could not complete the Open Session... command because Assertion in "..\ PtSess\ PtSess_RunTime.cpp", line 16689.
(Use the Copy button to copy this message to the clipboard.) while translating Region Group List
The same error occurs when I'm trying to open a session backup file, however it doesn't occur when opening other sessions.
I'm running Pro Tools 11.3.1 on Windows 7.
I hope anyone out here can help me out with this!
Jaap
Old 12-12-2017, 11:17 PM
Ben Jenssen's Avatar
Default Re: Could not complete the Open Session
I don't know about the error, but assuming it's a corrupted session file, I would start by creating a new session and import the tracks. Maybe a few at a time, and checking that they work, in case there is just one track or plugin causing the error.
Old 12-13-2017, 10:57 AM
And if that doesn't help, try these:
1-try opening an auto-backup session
2-Hold SHIFT while you open the session(which will make all plugins inactive). If this allows the session to open, then you probably have a bad plugin(did the session always get used on your setup, or did it come from another studio setup?)
3-trashing prefs might be worth a shot
4-last-ditch idea; create a blank session at a different sample rate(IOW, if the corrupted session is at 44.1K, make the new session 48K) and try importing session data and let Pro Tools apply SRC(sample rate conversion).
song will not open, could not complete the open session commandbecause...while transl SNAPPER Pro Tools 9 6 02-11-2017 11:32 AM
Could not complete the Open Session... Carpedrum macOS 0 09-14-2011 02:31 PM
Could not complete the Open Session? nmeisyou Pro Tools M-Powered (Win) 4 09-15-2010 04:12 PM
.. Could not complete "Open Session.." shtik Pro Tools TDM Systems (Mac) 2 06-08-2007 08:28 AM
Could not complete the open session mado 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-14-2007 11:42 AM
