PT 8.01cs1 / zoom in-out bug is back !!!
I've started a new session today with midi tracks. I'm getting this weird bug that stops me from zooming back and forth in the edit window... No matter what, R and T keep zooming in to the max and then stuck, no way back! All my sytem is clean with latest pi versions, etc, etc... What gives Digi ? A |
Re: PT 8.01cs1 / zoom in-out bug is back !!!
I dont know if this is what your talking about, but im having a zoom in problem with a session that has a few midi tracks.
I cant seem to zoom in enough to see the waveform lines. I can zoom to see the colored in waveform, but cant zoom to see when it turns into a thin line thats not colored in. Is this the problem your having? Runnin PT 8.0.1 on a PPC mac. |
No this was a known bug in 8.0-8.01. I believe it was fixed in 8.03, but bad luck if you're on PPC :-(
Check this thread http://duc.digidesign.com/showthread.php?t=244689 |
To add some more confusion to this...my zooming issues started in 8.03 I had to go back to 8.01 last week. All is well now. 8.03 and 8.03cs1 was a disaster on my system. I'm using LE but this seems to be affecting some HD and LE users.
Thanks Hause!! |
The same here.
I just made a fresh install up to PT 8.0.3 cs1. I cannot zoom vertically on my midi tracks. ( I used to be able to do it in some projects but it stopped all of a sudden). Vertical zoom on audio tracks works fine. Toggle zoom works fine. "R", "T" zoom works fine. M y midi tracks are frozen! help!!!!! digi? |
anybody having this issue?
Is this going to be fixed in the next upgrade? |
This issue has been addressed as a bug... but it is easily fixed. It seems to stem from an issue related to the default session length. If you go into preferences and reduce the session length to a reasonable amount of time, the bug should vanish. By reasonable I mean, if you're working on a song that is 3:30... the session length really doesn't need to be any longer than 10-15 minutes really... Or if you want a bit more room, I usually put it around 30 minutes.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
EuCon 2.6.2 not seeing PT8.01CS1 | Erik Zobler | Artist Series | 4 | 03-20-2012 11:51 AM |
Zoom Bug Is Back in 10.0.1 | Digi Superstar | Pro Tools 10 | 3 | 02-02-2012 06:07 PM |
The zoom/record/zoom back bug... | fishkarma | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-19-2010 08:11 AM |
Save bug in 8.01cs1 | LFO | Pro Tools TDM Systems (Mac) | 6 | 11-14-2009 06:13 PM |
8.01cs1 | K.I. | Pro Tools TDM Systems (Mac) | 13 | 11-13-2009 12:37 PM |
