  #21
Old 04-04-2021, 11:48 AM
Default Re: 2021.3 graphics glitch?
Originally Posted by Becharax View Post
even rolling back now still kept those graphical glitches .... any way to reset or something ?
I would make an image backup of your drive using something like Carbon Copy Cloner first.
Then format the drive and install the OS (use a compatible previous version if you want) and then install Protools 2020.12. Check that everything is working properly. Start installing any 3rd party plugins and test each time.
If you have other applications on that computer, reinstall those and restore your data files.
I know this is tedious and time consuming, but you asked for the best way to roll back/reset.
Obsidian Dragon
Mac Studio M1Max - 64GB
  #22
Old 04-05-2021, 02:07 AM
Becharax's Avatar
Becharax Becharax is offline
or I can simply wait for a new version ?? there is no way I can go back and re install everything i need weeks ...
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840/Slate VMS
https://open.spotify.com/artist/7KfV..._branch=1&nd=1
  #23
Old 04-05-2021, 04:34 AM
If you prudently saved all your installers to a safe place then it shouldn't take weeks or even a week. Maybe a day or two at the longest. Been there/done that before.
  #24
Old 04-05-2021, 05:09 AM
Becharax's Avatar
Its not just about installing .... It's also about presets, tweaks, labels etc ... would definitely not hurt to wait for the next update to install it over since I just renewed my support plan and I am working on Logic in the meantime
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
  #25
Old 04-05-2021, 05:34 AM
Do you have a working clone you can go back to? You should. Always make a clone then disconnect it from the computer BEFORE making changes. That way you can go back in time. I keep my clone drive right next to the computer disconnected and ready to go. 15 minutes to make the clone. Done and safe.
But seeing as not a whole lot of people are seeing it I wouldn't hold out hope of a quick fix. You would think I'd see it being as how I'm running on an unsupported OSX (10.13.6) with all different developer's wares and no problem.
  #26
Old 04-05-2021, 05:42 AM
Becharax's Avatar
ah so that explains it all !! ur still on High Sierra !! I am on Big Sur ... therefore the Graphical Glitches
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
  #27
Old 04-05-2021, 06:39 AM
Becharax's Avatar
Guysssss I sorted it out .... Try switching to Light Mode in Big Sur instead of Dark Mode and Reduce Transparency and Motion in Accessibility Options Display in Settings and you're good to go !! Avid might wanna check this up though
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
  #28
Old 04-07-2021, 12:16 AM
Paulienat's Avatar
Paulienat Paulienat is offline
On Mac Pro 2019 with Radeon Pro 580x, Catalina 15.7 and PT 2021.3 I don’t have this bug.
Hope it can help making a specs comparison.
Mac Pro 2019 - Monterey - Macbook Air M1 - Apollo 8p (x2) - Apollo Twin X - Ferrofish 16Mx - Avid S1 Multi-unit
  #29
Old 04-07-2021, 06:41 AM
Becharax's Avatar
It's a big sur thing !
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
  #30
Old 04-07-2021, 08:54 AM
paul_g's Avatar
paul_g paul_g is online now
Default 2021.3 graphics glitch?
It still happens in traditional mode. But it’s not that bad. I’ll give the other setting you mention a try.
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Graphics glitch every 60 seconds in 12.5 [SOLVED] DJ Hellfire Pro Tools 12 5 03-29-2018 01:29 PM
Graphics glitch in 12.8.2!! Cryos Pro Tools 12 3 12-12-2017 11:51 PM
Air Plugins Cause Graphics Scaling Glitch on 4K Display jarwady Pro Tools 12 10 07-03-2017 03:51 PM
Anybody sees this graphics glitch? Meads Pro Tools 12 12 09-03-2015 10:46 AM
PT8 - Pan Window Graphics Glitch JamesH Pro Tools TDM Systems (Mac) 0 08-19-2009 10:04 AM
