Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 05-04-2013, 02:31 AM
l.m l.m is offline
Default record by m-audio and fast track ultra 8R
hi
I have a M-audio Fast Track Ultra, i want to recording voice by 8 microphone ,microphone input to be separated, What software is used to record each mic signal separately?
pro tools v8 mixing mic signals and gives one output,
I want to have separate outputs for each microphone.
what do i do?
thanks
Old 05-04-2013, 10:49 PM
Default Re: record by m-audio and fast track ultra 8R
Why do you need separate OUTPUTS for this? You can record 8 mics to 8 separate tracks with this interface. If you truly need 8 separate outputs, there are several on the market, such as
Avid/Digidesign 002/003
Focusrite Pro 40, LS56
MOTU 828 Mk II
M-Audio ProFire 2626
Most of us that work with a native Pro Tools setup(no HD hardware) do just fine with a stereo output feeding the monitors, and a few outputs for creating custom headphone mixes(if we record bands).
Old 05-05-2013, 01:26 AM
l.m l.m is offline
Thanks very much for reply
For my project I need to microphone output signals separately But microphones are recorded simultaneously,How to separate signals recorded by each microphone is available?
I bought the device Fast Track Ultra 8R ,It has 8 separate inputs for mic. I need the software to give me a separate microphone signals .
What software I use to achieve this goal?
Old 05-05-2013, 09:55 AM
Pretty much every DAW in the world does this. Its called "Multi-tracking" It puts each signal(microphone, DI, virtual instrument) on its own track(could be a MONO track or a STEREO track). Each and every track is a separate audio file, and each can be edited and processed in a myriad of ways(change the EQ, add compression, reverb, echo.....). Then all those individual tracks can be exported, or mixed right "In the box"(also called ITB).
Old 05-06-2013, 03:01 PM
zedhed's Avatar
zedhed zedhed is offline
Whichever software you use, you'll need to read the specific manual on how to create tracks & route Input & Output (I/O) signals using buses, digital or analogue paths either to a physical interface and/or within the software itself. I/O requirements are met with ones choice of audio interface. It is at the interface where physical I/O limitations become apparent. In your case, if I recall correctly the M-audio Fast Track Ultra has 6 analogue outputs.
Within the program it's just a matter of selecting the I/O's by way of a drop down menu on each track to send and/or receive signals.
Typically within the software one would create separate tracks for each required signal (Mic, guitar, piano & so on), select appropriate I/O paths on each track and mix down to a stereo output. As Albee stated practically any audio editing software enables this to be done. Your physical routing options are determined by your interface capabilities. If you want to send say 8 separate audio channels from within the software mix to separate physical outputs you'll need an interface with a minimum of 8 outputs. Typically a lot of interfaces only provide 2 outputs since most non professional requirements mix down to a mono/stereo pair.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 11-28-2013, 06:53 PM
kabolling kabolling is offline
can i record all 8 xlr on adobe audition 1.5
Old 11-29-2013, 06:54 AM
JoelG's Avatar
JoelG JoelG is offline
Yes, you should be able to do this. Make sure you're using the ASIO driver (not DirectX) when you setup Audition. Then assign each input to a separate mono track.
Here's a setup guide for Audition 3 that might help:http://www.m-audio.com/index.php?do=...46977e13f98c8e
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 03-12-2014, 03:17 AM
shadowdaze shadowdaze is offline
I have an m-audio fast track ultra and would like to route each of the four mic inputs to four separate, individual outputs. However, no matter what I do all mic inputs automatically always go to all outputs. Even when my DAW (Cubase 5) is closed each of the inputs always send to all outputs. How do you make each individual input go to an individual output and not all outputs? Thanks a lot.
Old 03-12-2014, 09:05 AM
JoelG's Avatar
What DAW software are you using? In Pro Tools you should be able to set the output for each individual track, the output is to the right of where you set the input on each track.
Joel
Jam Space:
Home:
Rig:
Old 03-24-2014, 01:02 PM
Apologies! I believe that Pro Tools SE is limited to only 2 record tracks at a time. In regular Pro Tools, you can record as many inputs as the interface can handle(up to 32 maximum). HD/Native with HD IO allows for 64, and HDX goes higher.
PT MP9 questions with M-Audio Fast Track Ultra 8R jglunt2112 Pro Tools M-Powered (Win) 6 10-28-2013 09:12 AM
M-Audio Fast Track Ultra Help! Szenasi FireWire & USB Audio Interfaces (Win) 2 05-26-2013 11:55 AM
5.1 with M-Audio Fast Track Ultra 8R Elby Post - Surround - Video 3 05-25-2012 08:43 AM
Record audio from pc to Fast Track Ultra carlos.yanac Pro Tools M-Powered (Win) 0 03-02-2011 12:36 PM
is there a driver yet for m-audio fast track ultra? montelee Pro Tools M-Powered (Mac) 2 08-11-2008 10:55 AM
