Old 04-27-2007, 12:40 PM
djd2 djd2 is offline
Default change sample rate info for audio file
I'll try my best to explain my problem clearly.
I started a session in PT 7.3 at 44.1 / 24. I was clocking from my Octopre and it was inadvertently set at 48. The session records and plays back fine but if I mix down to 44.1/16 then the resulting track plays slow.
I think protools thinks the session is 44.1 even though it externally clocked at 48. I believe I need to change the header info for the audio files so they are 48 not 44.1 then import into a new session.
I never had this issue pre-7.3 as I would get a clock mismatch error and pro tools would revert to the internal clock source. In this case the digi002 sample rate light flashes suggesting it is not locked. but still plays and records fine.
Thanks, Dave
Old 04-27-2007, 06:19 PM
jes's Avatar
jes jes is offline
Default Re: change sample rate info for audio file
you can do this in Bias Peak 5.2. all you have to do is get the file's info and change the sample rate to what you want. not sure if anyone you know has that application, maybe a demo might work?
http://www.jonathansegel.com
Mac Pro Nehalem 2.8Ghz Quad 32GB RAM
Macbook Pro 2.8Ghz 16GB RAM
PT 2020
UAD-2 Apollo Quad, PCIE and Satellite
Bit Depth and Sample Rate and Audio File Type gavriil1 Pro Tools 10 5 11-20-2012 12:56 PM
LTC audio file and sample rate conversion ericabasnicki Post - Surround - Video 6 01-31-2011 12:55 PM
Pro Tools LE 8.0.3 Audio File Length change upon import / Sample Rate issue PhillyMike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-10-2010 06:49 PM
How do I manually change the sample rate on 002R with Core Audio? rastro2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-14-2008 09:46 AM
Altered Sample Rate doesn't Change File Playback?? dbates 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-22-2004 05:54 AM
