Old 11-26-2020, 05:26 AM
Reckless Erik Reckless Erik is offline
Default Mac system audio and DADman
Help!! How on earth do I connect the system audio output of my Mac (iTunes, Soundminer etc...) into DADman? I know I can physically connect it wired but there must be another way. Dante? HOWWWWW????
nickcath@internet.is
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.14.6, PT Ultimate 2020.12 HDn, MTRX Studio, Avid Artist Control, Avid Artist Mix...,
MacPro 3.5GHz 6 core 64GB RAM OSX 10.14.6, PT Ultimate 2020.12 HDn, MTRX Studio, Avid Artist Control, Avid Artist Mix, PT Dock...
Old 11-26-2020, 05:33 AM
Marsdy Marsdy is offline
Default Re: Mac system audio and DADman
You could use this: https://www.audinate.com/products/so...tual-soundcard
Mac audio then appears as a source on the Dante network that can be patched into DADman.
Dave Marsden
UK
Old 11-26-2020, 06:37 AM
Sorry Dave but this is just not happening here. What should I be using. Dante VIA or Dante Virtual Soundcard?
Newcomer Audio Post
Old 11-26-2020, 07:07 AM
At last success. The MTRX is talking to the Mac Pro and vice versa via Dante. Whew. That was a process.
Newcomer Audio Post
Old 11-27-2020, 01:54 AM
Johnny Hulst's Avatar
Johnny Hulst Johnny Hulst is offline
I too started with a Dante connection, but every time when I opend a sesseion with another samplefreq. I had to manually set the mac's dante samplefreq. to the corresponding samplefreq.
In the end I bought an RME AES pcie card which switches automaticly with a samplefreq change.
Johnny Hulst
Hulst Audio Engineering
MacPro (2019) 3,3ghz 12-core, 64gb Ram, 2x 1Tb SSD
1x Avid HDX & 1x UAD-2 Octo & 1X RME Hdspe AES
1x Sonnet M.2 4x4 PCIe (4x 250gb Samsung980pro)
1x Sonnet Allegro Pro USB-A 3.2, 4-port PCIe
1x MTRX - 8ch. mic/pre-card & 8ch da-card, 64-Channel IP Audio Dante Module,
MADI Module for Base Unit with SFP/LC module multimode 1300nm low output LED
1x MOM by DAD
4x 192 I/O (64 analog inputs)
1x HD Native Thunderbolt
Avid Artist Mix
2x Genelec 1237A Sam
2x Genelec 1031A
2x Avantone mixcube
Rupert Neve RNHP
http://www.hulst.nu
Old 11-27-2020, 03:33 PM
uptheoctave uptheoctave is offline
Had the same problem and for a long time I used an Apollo going into the MTRX via analogue.
I've just bought the 128 channel MTRX Dante Card (as I am out of Dante channels) and that is supposed to SRC.
I'll advise if that is the case when it arrives.
James Richmond
http://www.uptheoctave.com
Audio Production Reviews and Technique
Latest article for Pro Tools Expert:
"DAD Monitor Operating Module review"
https://bit.ly/30HGqPv
Old 11-27-2020, 03:48 PM
I agree, this is really frustrating. Even more annoying is that, at least under Catalina on my Mac Pro, Dante Controller often fails to reset the sample rate of DVS (you can change it but it has no effect).
Old 12-01-2020, 10:39 AM
samxnova samxnova is offline
I need some help with bringing both MAC audio and PT via Dante to Dadman.
Dante 1-6 is PT 5.1 routing. and 7-8 MAC Audio.
how can I send MAC AU to PT L&R Audio at the same time? it seems that only one source can be routed to one output or I'm missing something?
UPDATE: got it working by changing Switch monitor to Sum. just want to make sure this is the right way to monitor both Mac audio and PT via Dadman.
Thanks.
Rock Studios Inc.
Old 12-01-2020, 01:27 PM
It is.
Old 12-01-2020, 04:04 PM
creativecontrol's Avatar
FYI - DADman 5.4.4.2 is now available in Avid accounts and I would highly recommend updating to it. It includes numerous bug fixes.
best,
Jeff
Jeff Komar
Solutions Specialist, Pro Audio
S6 FAQ
DADMan 2.1 routing out of Mac Goombot Pro Tools 2020 3 10-21-2020 09:08 AM
DADman disconnects pkingduk Pro Tools HDX & HD Native Systems (Mac) 12 07-26-2020 05:22 AM
DADMan goes wonky Jared_TL Pro Tools HDX & HD Native Systems (Mac) 5 12-29-2019 02:06 PM
DADMan Firmware - When to Flash? jdh95 Avid S6 5 09-11-2019 10:00 AM
DADman and Mojave? jgaz Avid S6 15 06-30-2019 08:25 AM
