Old 11-22-2010, 04:15 PM
Calvinc3 Calvinc3 is offline
Exclamation No sound from XMON cue outputs
DUC,
I recently upgraded my Pro Tools HD software from version 8 to version 9. I am running Pro Tools HD3 on a Mac Pro with 8 Xeon [email protected] GHz, 6 GB of RAM, primary HDD is 600 GB, with two 1 TB drives for recording. I have a D-Command Main Unit with one Fader Module. I am using a 192 I/O as my primary audio interface, with a 96 I/O as my secondary audio interface. I have everything connected just as it is shown in the D- Command manual (XMON main outputs 1 and 5 to the control room speakers, cue outputs 1 and 2 to the recording room monitors, and cue outputs 3 and 4 to the headphone amp). The output from the 96 I/O is routed to the Cue Inputs. When I was using Pro Tools version 8.1, everything was working properly. However, after I upgraded to version 9, I was no longer able to get any sound from the cue outputs. The only change in my studio has been the upgrade to Pro Tools 9.
I also have a Creation Station PC running Pro Tools 8.0.4 through an 003 Factory+ Rack in the same studio. I connected the recording room monitors directly to the main outputs of the 003, and they worked fine. I'm using Pro Co DB 25 to XLR (male and female) and quarter inch TRS for routing audio signals between the 192 I/O, 96 I/O, and the XMON. I've checked all of the cables and everything is working properly. Please help!
Calvinc3
Old 11-22-2010, 04:51 PM
Craig F Craig F is offline
Default Re: No sound from XMON cue outputs
did the Cue levels get turned down, deselected inputs, or turned off?
Thank you,
Craig
Old 11-22-2010, 05:28 PM
jjsoundoc jjsoundoc is offline
Also check that the i/o output for cue is set to analog.
JJ
Old 11-27-2017, 12:46 PM
ffarr ffarr is offline
having same problems with no sound from cue sends outputs, did you get this problem resolved?
Frank
Old 11-28-2017, 11:33 AM
7 year old post......
Old 02-26-2018, 09:47 AM
TopStudioMiami TopStudioMiami is offline
I have the same problem.! someone solved it?
Old 02-26-2018, 09:48 AM
[IMG] code is Off
L & R or Mon Outputs via hi-end Sound Card ? ChuckLogan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-08-2010 10:43 PM
Xmon Stereo outputs bearease ICON & C|24 2 02-24-2010 06:15 PM
Xmon Outputs 98wildcat ICON & C|24 7 08-19-2007 10:59 AM
Hum at XMON´s mini speakers outputs i.celma ICON & C|24 3 12-01-2006 03:27 PM
No sound from outputs 3 thru 8 paganini12 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 01-07-2001 11:05 PM
