Old 04-22-2002, 02:12 PM
dave-G dave-G is offline
Default Restoring DATa to mix hardware??
I've just run across some 10-year old DATa backups I made and I'd really like to rescue them from the archive.
Is there a version of DATa that works with the Mix-era hardware?
-dg
DAVE GREENBERG
SONOPOD MASTERING
Old 04-22-2002, 08:26 PM
Jeff D. Jeff D. is offline
Default Re: Restoring DATa to mix hardware??
I've still got a Sound Tools 1 rig set up for this purpose... if you need them done I could transfer them for a reasonable fee.
Good luck,
Jeff D.
www.jephthastudios.com
Old 04-23-2002, 08:08 AM
DigiTechSupt's Avatar
<font size="2" face="Verdana, Arial">No. DATa is only compatible with AMIII, PT Project and Disk I/O hardware.
Brent
Avid Audio Tech Support
Support FAQ
Old 04-23-2002, 10:08 AM
mpayne mpayne is offline
It is with trepidation that I step on the answer of a Digidesign person, but it can be done on a Mix system ... if you have a vintage farm card installed. i know - I've done it
Malcolm
Old 04-24-2002, 05:53 AM
Malcolm
<font size="2" face="Verdana, Arial">I may have access to a vintage farm over the next day or so ... How do you do it?
-dg
DAVE GREENBERG
SONOPOD MASTERING
Old 04-24-2002, 08:19 AM
As far as i remember, (it was some months ago0 I just booted up DATa and it ran as it always used to on my Nubus system - reads from DAT, writes to disk. i believe I got the hint from an old post on this site. one thing - i would still have been using DAE 5.0 at the time, in case that makes a difference
Malcolm
Old 05-07-2002, 09:19 AM
Okay--trying to kludge my way through this. Still no luck.
On this system, I've got a Mix+ rig with a vintage DSP farm. I've connected the 888/24 to the vintage farm, but I can't get through the hardware setup dialog. It shows the little i/o thing next to the DSP farm when selecting what i/o is connected where, but . . if I try to set that to 888/24 and press <ok> it just cycles me back around to the "you need to chose an audio interface" dialog.
Anyone have any further tips? I'm just about too paranoid to try and install an old version of DAE, but is that what's going to do it?
-dave
DAVE GREENBERG
SONOPOD MASTERING
Old 05-07-2002, 06:34 PM
Hey,
Like i say, i think i would have been using 5.0. it's a little bit of a hassle to change over, but not too much. In the system folder, take the Digi system init, stream manager and dsp manager out of the extensions folder, and the DAE out of the DAE folder and put them in a safe place. then download the 5.0 stuff, which i think does not include as many files, and install them in the same places. Then trash the digisetup and the DAE prefs file from the prefs folder.
Also, i do have an older 16 bit 888 attached to my vintage farm, so that my make a difference.
If i have time tommorrow, i'll do a test run to make sure I haven't been dreaming this all up!!
Malcolm
Restoring your "Preview"? uno1234 ICON & C|24 2 04-23-2008 12:47 PM
Restoring DATa backups plutone Digidesign Hardware & Software 15 11-30-2007 04:46 PM
restoring old files viaspiaggia Pro Tools TDM Systems (Mac) 1 06-06-2007 09:45 AM
Restoring DATa backups plutone Pro Tools TDM Systems (Mac) 4 01-26-2006 08:34 PM
DATa, any way around needing the hardware? Murdockscott Digidesign Hardware & Software 2 09-14-2004 03:05 PM
