Old 06-06-2018, 01:25 PM
cmhawke cmhawke is offline
Default Comparing two audio files
Is there a process in PT and/or another app that can compare two identical/similar audio files (like two different bounces of the same track, or bounces of slightly different versions of the same track) and show/report any differences? Something analogous to Photoshop's Difference Blend Mode to compare layers may work. The formats of the files to compare would be the same (16b or 32b wav). The manual methods I use at the moment are not ideal.
Old 06-06-2018, 02:45 PM
BScout BScout is offline
Default Re: Comparing two audio files
Phase invert one against the other at unity level and print the sum of them together. Then look at the resultant file in iZotope RX (or just listen). Everything exactly the same will cancel leaving the difference
usaved PT session saving unsaved audio files to audio files folder mermermer Pro Tools HDX & HD Native Systems (Mac) 1 07-18-2012 11:50 AM
Audio files on one FW Drive render blank audio files when copied ridmik Digidesign Hardware & Software 4 03-30-2012 12:55 PM
comparing tracks (A/B) jlnelson19 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-27-2009 09:27 PM
comparing D/A converters.... Ray soly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-04-2005 06:43 PM
Fade Files as Audio Files in "Missing Audio" ?? CCash Pro Tools TDM Systems (Mac) 6 05-18-2005 09:00 AM
