Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 08-08-2019, 04:20 PM
briaboy briaboy is online now
Default Adding effect on part of track only
Hi - in PT 2019, how does one insert an effect on part of a track only? I'm trying to do it with AudioSuite, but I get a message saying "no audio selected" even though I have highlighted the section I want to have the effect on, and armed record. Any ideas? Thanks!
Old 08-08-2019, 04:25 PM
BScout BScout is offline
Default Re: Adding effect on part of track only
Audiosuite is offline. You don't arm or record. You select a region and render and a new file is written over the top.
An insert plugin (AAX) is online. You insert it on the track itself. Once again you don't arm and record. You automate a bypass if you only want a region affected using automation. That can be done with automation record if you want.
This isn't a PT2019 thing. This is how pro tools has worked from almost the beginning.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 08-08-2019, 04:53 PM
Here is a screenshot. I hit render and this happens...
Old 08-08-2019, 05:00 PM
Macsearcher Macsearcher is offline
Try separating the clip/region that you want to treat.
Also, I may be way off on this but are you postitve that this is audio? It looks like a midi event.
Old 08-08-2019, 05:01 PM
It's an instrument track. Is it only possible with audio tracks? Might be the problem, well spotted!
Old 08-08-2019, 05:20 PM
Yes. Only Audio.
(also why "no audio is selected" is the warning message -- because you've selected MIDI)
Old 08-08-2019, 05:36 PM
So there's no way to just add an effect to a part of an instrument track?
Old 08-08-2019, 05:41 PM
amagras amagras is online now
Yes, automating an insert
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 08-08-2019, 05:49 PM
Yes, thought so, a bit tedious, but here we go....thanks!
Old 08-08-2019, 06:01 PM
If the effect is time-based(reverb, delay), its probably better to send to an AUX track>insert the effect on the AUX track and automate the send Automating Bypass is fine, but with reverb or echo, the bypass will kill the effect abruptly(maybe not what you want)
adding support plans to PT12 licenses that were part of the EDU upgrade? mesaone Licensing & Accounts 3 11-02-2015 09:24 AM
Adding effect to a section of Instrument Track. sackj Windows 4 02-23-2013 05:49 PM
Is this the best way to re-record part of a track? products7074740 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-16-2009 10:12 PM
click track but were not 4/4 on a part broken81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-09-2007 03:35 AM
Adding Effects to a selected Part of a Track lmoore 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 20 05-17-2006 02:28 PM
