Old 08-02-2019, 12:01 PM
pasanta pasanta is offline
Default Router, Hub, Switch?
I need to use an Artist Mix and Control on a MacPro. But I also need to network a PC for Vienna Pro Ensemble and both Mac and PC need to have internet access (not WiFi). So thats more ethernet connections than I have. Do I need a router, hub or switch? Googling those is a bit confusing.
Old 08-02-2019, 12:22 PM
BScout BScout is offline
Default Re: Router, Hub, Switch?
Switch.
Connect your current internet access device (which is a gateway/router) to this newly purchased switch with one ethernet cable. Connect all your other devices to the switch.
That's it.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Ethernet Switch or Router? simonjewel Artist Series 15 09-13-2015 04:09 AM
will a router switch with no internet connection work? Dingo90 Artist Series 5 01-05-2015 12:38 PM
Best switch/router for Artist series? ThosSounds Artist Series 2 12-21-2014 04:16 PM
Router/Switch conflicts / Ip address problems Xill Artist Series 10 08-10-2011 06:44 PM
Sticky Faders after router switch..... s0nguy ICON & C|24 1 10-16-2004 07:19 AM
