Old 05-23-2011, 08:34 PM
Convectuoso Convectuoso is offline
Default "EUCON Personality could not be loaded" Error?
Hello all!
I just purchased a lovely Euphonix MC Control V1 yesterday, but cannot seem to get Pro Tools to recognize it/work.
It works fine on other apps like Safari etc but when I try to enable EUCON it does not seem to want to play nice.
The above message comes up.
I've logged with Avid support and their help has not yet fixed it, but waiting on a response to my last email so thought I'd put it here to see if anyone has a fix?
I'm on 10.6.7 and I've trued both 2.5.6 and 2.5.7 to no avail. And on Pro Tools 9.0.2.
Any help would be very much appreciated as I have a mix to do tomorrow and would love to have this puppy up and running!
Old 05-24-2011, 10:40 AM
noeqplease noeqplease is offline
Location: Los Angeles, CA, USA, Planet Earth, Solar System, Milky Way Galaxy
Default Re: "EUCON Personality could not be loaded" Error?
You could run Onyx to clean up your permissions, and also trash ALL the Pro Tools preferences. There is a tool on this forum for that too...
Database and prefs helper.
Also, you should REBOOT the computer once you've deleted the preferences and cleaned up caches / permissions, etc.
Lastly, once your EuCon software sees your MC Control correctly, you should check it's firmware versions, and update it if necessary.
Cheers
Nick Sevilla
nick@nicksevilla.com
Old 05-24-2011, 11:08 AM
DigiTechSupt's Avatar
This sounds like a corrupt EuCon personality. I've uploaded a new copy of it - download it, unzip it, trash the one currently in the Controllers folder inside your Pro Tools folder, put this one in it's place, trash preferences, restart and try again.
EuCon controller profile
Avid Audio Tech Support
Support FAQ
Old 05-24-2011, 12:01 PM
Thank you very much, I will try this as soon as I get on my main machine.
Will post results.
Old 05-24-2011, 01:23 PM
Still no luck
Old 05-24-2011, 04:56 PM
Originally Posted by Convectuoso View Post
Still no luck
Hmm. Ok, can you try this?
Navigate on your system hard drive to Users>your account>Library>Preferences and place the following files in the trash:
com.euphonix.eucon.plist
com.Euphonix.EuControl.plist
Then navigate to your system drive>Library>Preferences and put the following files in the trash:
com.euphonix.EuConSystem.plist
com.euphonix.install.EuControl.plist
If that still doesn't work, go to the Euphonix folder in your applications folder and run the uninstaller, restart and reinstall 2.5.7. You probably should trash those same preferences files and Pro Tools preference files after doing so, restart, and test again.
Support FAQ
Old 05-25-2011, 06:18 PM
That fixed it :) All up and running, thanks for your help!
Anyone experiencing the same problem, do exactly the above and it should fix it.
Old 05-26-2011, 09:56 AM
Excellent! Glad to hear it!
Support FAQ
Old 08-12-2011, 05:51 PM
jesse p jesse p is offline
Where are the PC equivalents to this files on the mac?
I'm getting this Personality problem everytime I try to Automap RTAS plugs to use with Automap 3.
www.kdsound.net
Sound for film and Television
Old 08-12-2011, 06:25 PM
I've had some luck trying to load PT with out eucontrol running.. then shut down.. and restart pt after turning it on again..
But the sequence doesn't always work.
www.kdsound.net
PT10/Digi 003 - Error occurred while trying to load the controller personality "003" J-Xile 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-14-2015 08:36 PM
controller personality "EUCON" incompatible Pz5 Artist Series 8 06-04-2013 11:39 AM
"Error configuring CNTRL|24 Personality" in Pro Tools 10 with Control|24 jeff markham ICON & C|24 2 05-26-2013 10:56 PM
MC Control "eucon library is not loaded windows" djmichaelwenz Artist Series 1 10-05-2012 07:11 PM
2 Problems after Upgrade PT9 to PT10: "Controller-Personality MBox3" and "MP3.dll" Eviltubbie Windows 5 07-03-2012 10:39 AM
