Old 12-14-2004, 04:16 PM
gwest gwest is offline
Default Stylus RMX and Digi 001
Is anyone successfully running RMX with Digi 001 hardware? Midi communication keeps hanging and the only workaround is to relaunch ProTools. This occurs even if Digi 001 is not utilized in the Midi Setup Prefs (USB controller only). Spectrasonics doesn't have much to say except for the fact that they didn't test with the 001 since it's no longer in production.
gw
Old 12-15-2004, 01:57 PM
Default Re: Stylus RMX and Digi 001
bump...is it just me?!?
gw
Old 12-16-2004, 08:08 PM
lwilliam lwilliam is offline
I wouldn't feel too bad. I've been reading a few posts on other forums where they're having trouble with the Stylus RMX in Logic Pro, too.
My guess is it's a Spectrasonics issue (new engine and all - it's really a version 1.0). Watch for a patch to come out soon.
If something does come out, post again. I've heard great things about the new library and the Chaos Designer.
Larry
PTLE8/002r;OS 10.6.4 2 x 2.26Ghz quadcore,6GB RAM, Waves Platinum, many other plugins...
Old 12-16-2004, 08:55 PM
senyc senyc is offline
I cannot even open RMX - PT crashes. I have not even heard any of the new loops.. Sh*t, I can't even authorize the thing.. Kinda lame - at least mention you are not going to support the 001.. Stylus Classic was unstable when first released too- nothing new.
gw, how do you get to actually open up RMX? Have you maybe installed the 6.4cs9 update - just curious/don't really expect this to change anything.
DP G4 1.25
DIGI 001/PT6.4/Live 4/Reason 2.5
Apogee Mini-Me/Mini-DAC
Mackie HR824s
Access Indigo 2
Old 12-17-2004, 06:28 AM
GlennO GlennO is offline
Yes, RMX has been tested and works fine with a Digi001 here, and it definitely works fine with Logic Pro . Check to make sure you're using the latest version, but if that doesn't help, contact tech support. And be sure to include your system specs. Thanks.
Glenn Olander
Spectrasonics
Old 12-17-2004, 06:33 AM
Oh, forgot to mention: sometimes hitting the transport start and stop a few times in PT can wake up PT's midi communication, so try that as a workaround.
Glenn Olander
Spectrasonics
Old 12-17-2004, 12:23 PM
Hey Glenn! Thanks for trying to help. Do you have any particular tips for us 001 users? I am expecting a reply from Spectrasonics tech support but I'd love to get RMX going asap. Any info would be greatly appreciated!
Current setup:
DIGI 001
DP G4 1.25(gigadesigns upgrade)
1.5 GB
PT 6.4/ OS 10.3.6/ Stylus RMX(1.1)/ Stylus Classic(1.1 - runs fine)
MOTU midi express 128
Roland A-33
Old 12-18-2004, 03:06 PM
Well, I got RMX to work. I opened it through Live 4.0.4 and authorized it - Live running as standalone. I then opened RMX in a PT session with no problems. It is a CPU hog. I you have a G4 and want no audio interruptions I suggest you audition the lighter loops first(hi hats, no kick etc.) and then the combo titled ones. If you try to audition a loop's combo version first and you get no audio, follow Glenn O's advice and start/stop on your transport a couple of times - do that when you first open your PT session as well if you are going to use RMX. As far as quality goes, I am not surprised. Eric Persing and team have done a great job once again!
Old 12-18-2004, 05:07 PM
AdamF AdamF is offline
Make sure you do have the latest version of RMX from the spectrasonics website. I have a 001 on a G4 dual 1GHz and it works great. It is somewhat more limited then on logic as far as separate outs and stuff, but I love it no less. AMAZING plugin. I think it is time for a G5 and 002R though
My Website
My Setup
Old 12-20-2004, 01:01 PM
Hey Adam, congrats on your Sullivan Room residency - I will try to make it on the opening night(will contact for list later). Keep up the good work. nicholas_
Need help w/Stylus RMX and 8.0.3 please...thx auge Virtual Instruments 11 03-31-2010 06:51 AM
stylus rmx and PT8 Mark Wheaton Pro Tools TDM Systems (Mac) 6 01-17-2009 08:16 AM
stylus rmx SNAPPER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-31-2005 05:02 AM
New Stylus RMX... AdamF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-18-2004 10:17 PM
Stylus Ozzie MIDI 1 08-08-2003 12:56 AM
