Old 08-11-2019, 08:12 AM
blue moose blue moose is offline
Default Nuendo 8 crashes EuCon
system os10.13.6 (HS), Nuendo 8.3.20.345, Artist MCMix with Eucontrol 3.5.
EuCon would often loose contact with the MCMix hardware, so after reading positive comments on more recent versions, I updated to 18.3.244 (not the last one).
Eucontrol does not even see the MCMix anymore. So I did a complete cleaning of all Eucon files and reinstalled the software: no change. Last version (19.7.…) is no different. After a few hours of trashing Preference files, rebooting the mac and trying about everything including a fixed IP address connection without success, I reinstalled Eucon 3.5: now Eucon sees and connects to the hardware.
Looks good, but now the eucon app crashes when I launch Nuendo 8.
Note: the MCMix works perfectly well when I boot on an older OS with the exact same hardware configuration.
If it is a firmware thing, since recent Eucon apps do not see the hardware, I can't access the firmware button in EuControl.
I have searched forums here and at Avid without finding any answer to the problem.
I'd be very obliged if anyone provided some help. Many thanks
Top
Old 08-12-2019, 09:31 AM
EddieJones's Avatar
Default Re: Nuendo 8 crashes EuCon
19.7 should be OK with that OS and N8. This is not a firmware thing.
When you say cleaned EUCOn please be aware that the new Installer doers a much better job of that. So try this to get back to 0. Install 19.7, reboot. Now run the installer again and select remove all Apps and remove all prefs. then reboot and install it again.
Let me know what happens...I'll look out for your post.....
What's it going to take to get Eucon to follow Nuendo? KeyplayerG Pro Tools | S3 15 08-30-2018 01:50 AM
Eucon 3.3.2 keeps dropping connection with Nuendo 7 KeyplayerG Artist Series 3 04-11-2016 08:58 AM
Will Avid C|24 control Nuendo 6 via Eucon, HUI or both? KeyplayerG ICON & C|24 7 03-18-2015 08:51 PM
Eucon 2.6.2 and Nuendo 5.5 Steven1145 System 5 11 08-14-2012 02:10 AM
Nuendo 5.1.1 and EuCon PhilippeCNA System 5 5 06-10-2011 12:25 AM
