Old 11-01-2016, 01:48 PM
ethandla ethandla is offline
Default Can't Delete Plugins
I demo'd Melda's plugin line (for whatever reason...) and now the demo has expired but all of them are still showing up in my plugin menus in the inserts list. I have literally deleted the entire folder containing the plugins (Library>Application Support>Avid etc.) and I searched my entire mac and the files are no longer anywhere to be found, but they are still showing up in my Pro Tools sessions. I cannot figure out how to get them to disappear, it makes no sense to me. Please help!
Old 11-01-2016, 01:51 PM
Default Re: Can't Delete Plugins
Ask this question from the 3rd party plugin vendor
Old 11-01-2016, 03:28 PM
You could try deleting the "installed aax plugins" doc then relaunch PT. it'll rescan the plugins folder.
~ Trashcan Mac Pro late 2013 - 64 GB RAM - 10.12.6 / Pro Tools HD 12.8.3 / HDX 2 + UAD2 PCIe OCTO in Magma Expressbox 3T / HD I/O's x 4 + 1 x 96io / Avid S6 M10-24-5 V3.6 ~
~ MBP 15" 2.8 Intel Core i7 -10.12.6 /Apollo 16 / Steinberg U22 / Artist MIx / Pro Tools HD 12.8.3 - UAD2 V8 / UAD2 Satellite DUO ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / HEAT / Magma PE6R4 / ProControl 24 faders / UAD2 QUAD PCIe ~ ARCHIVE RIG
Old 11-01-2016, 03:30 PM
System info please? Your profile only says you're always running the latest version of OSX but we need to know what exact version you're running. Also try dumping prefs and databases. Look for a user here named Pete Gates - he has a utility to help with that task.
Old 11-03-2016, 09:42 AM
I'm actually running OS X El Capitan, so not the latest... Whoops. Version 10.11.6, and my version of Pro Tools is up to date.
Old 11-03-2016, 09:50 AM
This sounds promising. Where exactly can I find that doc? Thanks!
Old 11-03-2016, 12:57 PM
ElCrapitan was one of the worst for PT. More info needed - what exact PT version? If you put this kind of stuff in your profile we wouldn't have to waste time with the back and forth like this. PT didn't become compatible with EC until PT12.3
Old 11-03-2016, 03:12 PM
john1192 john1192 is offline
Are you saying the plugins are in your sessions and grayed out ?? If yes, just remove each one .. And you only need to get rid of / trash the ones you do not want in your plugins folder, not the entire folder ..
Can you clarify please
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 11-03-2016, 04:09 PM
12.6.0 - as far as I'm aware, that's the most recent version. To answer the other question, all of the plugins are still showing up in my plugins list when I go to add a new insert. Additionally, the plugins actually load if I select it. SO it's got to be somewhere on my computer, even though I've searched my computer for anything with the name of the company (Melda) and can't seem to find anything, since I already deleted the plugins in my plugin folder in Application Support, the MeldaProduction folder in App Support, and another folder that I found just in ~/library also called MeldaProduction...
Old 11-04-2016, 12:09 PM
Ok turns out I'm dumb and there is another folder called library that also contains an Application Support and Avid folder on my computer, in addition to the one I had already deleted the Melda folder out of. But when I backed all the way out to my HDD, I found the actual Library folder I was looking for and deleted the Melda folder there. I don't have my iLok on me right now but I'm hoping that later when I try it, the problem will be solved! Thank you all for your help!
Old RTAS/DPM plugins - delete? briaboy Pro Tools 11 9 08-17-2015 12:18 PM
Reorganize or delete plugins Simpson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-28-2005 03:02 PM
Delete plugins, digifriend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-02-2004 04:51 PM
Which plugins to delete? Mike D. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-23-2003 04:00 PM
how to delete plugins? digifriend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-12-2003 02:22 AM
