Calling up AudioSuite plugins in PT Control
Hey All
I've been trying to figure out how to assign AudioSuite plugins to Soft Keys in PT Control. It seems to be the only drop down menu not included ! i'm sure theres an easy explanation though ... anyone ? Cheers Kevin |
Re: Calling up AudioSuite plugins in PT Control
Under windows pressing the ALT key (on the keyboard) activates the menus at the top (denoted with underlines), then pressing the "a" key shows the AudioSuite dropdown menu. There used to be a way to get this to work with a Softkey with some keyboard shortcuts but I just tried this here again but it did not work... bummer.. if we could get access to the menus at the top via a keyboard shortcut, then a Softkey with some keyboard shortcuts would do exactly what you need. |
You can use window configs for this. They can be recalled with soft keys and if you are using the same audio suite PI in different sessions you can save them in a template session and then import in other sessions with import session data.
Thanks for the suggestions guys. I also came across this in case its useful to anyone else.
Cheers http://www.pro-tools-expert.com/home...-plug-ins.html |
Unfortunately the above works great but not as a softkey . When trying to use the Eucon Command Keypad number - it seems to keep resetting to using the regular number keys instead.
Audiosuite Plugins | odeu87 | Pro Tools TDM Systems (Win) | 2 | 07-21-2010 09:35 PM |
Plugins Vs Audiosuite | gz131 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-20-2004 09:24 AM |
audiosuite plugins | prs24 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-30-2003 02:11 AM |
Audiosuite plugins in HD | waves3 | Pro Tools TDM Systems (Mac) | 5 | 03-29-2002 12:27 AM |
