HD Native Thunderbolt disconnecting from Ableton Live 10.x
Hi
When i use HD Native Thunderbolt with Ableton Live 10.x (OSX, High Sierra), it disconnects either randomly or when i perform certain functions (but not all the time), like when i change i/o's on channels or use certain plugins. The program doesn't crash, the soundcard just disappears from the device menu and the audio engine turns off. This happens with all buffer settings. This is so frequent to the point it is nearly unusable. This also doesn't happen with any other driver from 4 different soundcards i have here. Anyone has any idea how to fix this? It's impossible to work Thanks |
Re: HD Native Thunderbolt disconnecting from Ableton Live 10.x
Is the HD driver version compatible with High Sierra?
I guess. It's the 2019.5
How can i check it? |
Thanks
I did notice that is a new driver the 2019.6 and i just installed it, gonna check how it works. Still wondering if someone else has this problem, as i found in the forum at least people with HDX with the same problem |
Well, i just updated the driver to 2019.6 and no change. Still the same problem...
Have you already contacted Avid support on this? If not, please do so
Yes of course, and Ableton support too, before posting in the thread!
No answer yet and was hoping some user had some valuable advice... |
Try a different Thunderbolt port. Try a different Thunderbolt cable. Remove all other Thunderbolt devices to narrow down the problem.
Thunderbolt can be finicky depending on what else is connected (not just on the same port but on the same system)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
That's an idea.
I'm trying some variations and one of them appeared to make the problem somewhat less frequent, but not solved. Needs further testing Also, it's weird because running PT 2019.5 with the same port, same tb cable and same interface is absolutely rock solid... |
Avid HD Native Thunderbolt and Thunderbolt Cables. | SoundEng1 | Buy & Sell | 0 | 10-30-2018 10:24 PM |
Does native+omini work for Ableton live | marchseventh | Pro Tools HDX & HD Native Systems (Win) | 6 | 04-10-2017 07:04 PM |
HD native thunderbolt with thunderbolt card on desktop PC? | martthie_08 | Pro Tools HDX & HD Native Systems (Win) | 9 | 10-12-2016 10:26 PM |
HD native thunderbolt through Echo Express SE Thunderbolt Chassis | hkj1 | Pro Tools HDX & HD Native Systems (Mac) | 1 | 11-06-2013 05:49 PM |
Ableton Live 8.4 Beta (Native 64-bit) | filosofem | General Discussion | 2 | 08-21-2012 09:26 PM |
