Old 02-26-2018, 06:18 PM
stewart@3p stewart@3p is offline
Default Best DNxHR Preset for working with video in Pro Tools
Hi there
Just been converting video in Adobe media encoder for working with Pro Tools and wanted to see if anyone could suggest the best preset to go with for frame accuracy and stability (working in 25fps).
Thanks in advance
Stewart
Old 02-27-2018, 12:05 AM
papalou papalou is offline
Default Re: Best DNxHR Preset for working with video in Pro Tools
Don't use DNxHR (way too big), but DNx36, which is good enough as proxy file.
Old 02-27-2018, 09:31 PM
Ahh noted.
Cheers for the feedback
Old 02-27-2018, 09:52 PM
Watagushu2013 Watagushu2013 is offline
DNx is Too old codec. The new LB is quite good and it doesn’t ask for much data rate.
Old 02-28-2018, 12:46 AM
MusoPro's Avatar
MusoPro MusoPro is offline
Yup have to agree DNx36 is your best bet.... the bigger files run fun with PT but if your working on multiple projects you can easily burn up 1TB pretty easy.
I have QT Pro 7. That way whatever I get from the client I can export as DNx.
But make sure you downloaded and installed the Avid video codecs first....
Best
Mitch
MacPro 2.44 8 Core
Mac OSX 10.10.5
PT 12.7
HD Native
SyncHD I/O
HD I/O
MIDI I/O
C24
Aja LiHi
Surround Setup
Old 02-28-2018, 02:27 AM
Too old ? Mozart's music is maybe too old as well ?
If it works, it's good, and DNx36 is perfect for audio post work.
DNxHR LB is a new horse, we have time enough to try it while DNx36 still works (which could be for years or decades).
Old 02-28-2018, 03:40 AM
tom_lowe tom_lowe is offline
DNxHR is designed for 4K and above. For resolutions up to 2K, DNxHD is still the way to go. If you're not working about 2K, you shouldn't use DNxHR.
Old 03-03-2018, 06:34 AM
LB is not design for any size or frame rate, that’s the beauty of it. It’s agnostic to size and frame rate. LB is like ProRes proxy.
Old 03-03-2018, 07:54 AM
DonaldM's Avatar
DonaldM DonaldM is offline
There's just too damn many codecs out there! I don't do any video editing and only import videos to PT 2018 to add music. The advice I got was to convert whatever the editor sent me to DNxHD, which I've been doing and it works just fine. Is that still the best option, or is there something newer that might be more efficient and take up less space? I use Brorsoft's video codec converter to make the conversion.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 03-03-2018, 08:14 AM
At 1920x1080 DNxHD 36 is your best bet.
HTML code is On
Pro Tools First Quandary About Working With Video Austin4 Pro Tools 12 4 07-12-2017 11:04 AM
Video not working in Pro Tools 11 mortenbrekke Pro Tools 11 25 02-15-2017 10:22 PM
DNxHR Marcel Risberg Post - Surround - Video 8 04-21-2016 11:17 AM
Syncing audio/video & Working with Premiere Pro and Pro Tools millsi Post - Surround - Video 6 02-07-2011 01:00 PM
Preset Menu Not Working! lukec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-08-2007 08:17 AM
