  #41
Old 09-18-2019, 03:35 AM
mightyduck mightyduck is offline
Default Re: Macbook Pro backup before repair
Ha. This time I got it to format as APFS and I added another volume to the container.
Now, sadly, I have to do the clone again. Not really sure why I am obsessing over this. : )
MD
  #42
Old 09-18-2019, 03:37 AM
JFreak's Avatar
JFreak JFreak is offline
Just for the sake of learning something?
Janne
  #43
Old 09-18-2019, 03:57 AM
I learned that computers are possessed. I did it the same. Some little blurb flashed on the screen about "MacOS Extended [journaled]" and then it formatted APFS, with container.
Now, in Disk Utility, there's a greyed out "ghost disk" right under the top level [top level is "LaCie Rugged USB-C Media" / "USB External Physical Disk • GUID Partition Map"]. The ghost disk says "lacie 3 - clone disk and so forth" / "USB External APFS Physical Store". And then there is the container housing the volumes.
MD
  #44
Old 09-18-2019, 05:35 AM
JFreak's Avatar
Glad you got it sorted out
Janne
  #45
Old 09-18-2019, 08:57 AM
This time it did not prompt for the "hidden disk". We'll see if it shows up.
MD
  #46
Old 09-18-2019, 09:43 AM
Don't worry about it, man. If no one else wants to help because you are monopolizing the thread, then I will try a different forum. I have a working clone drive, its just weird that it won't format as APFS, ...
I agree it’s weird, but you may have it sorted now and/or it does not matter that much if you just use A HFS+ partition if you have to. But the whole scary thing about your post was you reported your applications are missing. That potentially means your clone is not OK, and more important to worry about than APFS vs HFS+. It was totally not clear what you meant which is why I asked for details. I know you are under pressure and did not want you to think that was OK and rely on a bad clone and then get burnt. If *anything* still seems to missing still, please let us know what you see. The clone system should operate like the real thing (with sometimes a possible difference with desktop boot drive icon names/appearances, and any software relying on hardware configuration fingerprinting).
  #47
Old 09-18-2019, 12:33 PM
The applications are not missing when booting from the clone. Everything is slower from the clone [normal I would think]. It did not create a "hidden" partition this time as far as I know [nothing showing up in option > start]. There is another volume on the disk now that I created when formatting.
MD
  #48
Old 09-18-2019, 12:44 PM
Sardi Sardi is offline
It’s slower because you’re using a 5400/7200RPM spinning drive as opposed to the internal SSD in the MacBook Pro.
  #49
Old 09-18-2019, 12:59 PM
I know. I don't like that it did not create a "hidden" disk this time. Last time there was a dialogue prompt to do that and this time no. Maybe because its APFS this time?
MD
  #50
Old 09-18-2019, 01:06 PM
You are set! I would not worry about anything or mess around more.
If your hidden comment means there is no recovery partition, don't worry about it for now. If Apple replaced your motherboard you may get back a system running Mojave with a Mojave Recovery partition. We can help you manually replace (to match you OS) or delete the recovery volume on that system. Some folks don't like to use a recovery partition (if you have a bootable clones available you don't strictly ever need it--but it's more insurance if very bad things happen).
Experiences running Eleven Rack with a USB3 MacBook Pro or MacBook Pro Retina? Darryl Ramm Eleven Rack 3 09-18-2012 11:22 PM
Macbook Pro & External Drive Backup - Need Advice JCWarrior 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-24-2007 03:06 PM
help with pop repair willbgoode Pro Tools TDM Systems (Mac) 4 11-18-2004 08:39 PM
TRAVAN Tape Backup - compress audio backup or not ? stoneinapond Pro Tools TDM Systems (Mac) 2 11-28-2001 12:35 AM
888-24 repair JGriffith Pro Tools TDM Systems (Mac) 1 04-12-2000 02:15 PM
