Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 09-02-2019, 11:48 AM
lampmusic lampmusic is offline
Default Pro Tools Ultimate / HD Reinstatement?
A few years ago we switched most of our music production work over PT12 Native due to the cost of reinstatement for our HD system.
For band tracking we are still using our PT HD Native system running on PTHD 11.
If we were to come up with the $ to do the reinstatement on this system, are there any benefits? We are only doing tracking, no video, no surround.
Thanks in advance for your thoughts.
Main System MBP 2016 (touch strip) 16G Ram.
I own a PTHD 11 which I still use on a native system in main studio (not sure if is worth the $ for reinstatement)
Doing most of my mixing work in PT 12 vanilla.
OS X 10.12.6
Old 09-04-2019, 09:07 AM
Sugarnutz Sugarnutz is offline
Default Re: Pro Tools Ultimate / HD Reinstatement?
My personal thought is if your just tracking with it I see no advantage going to the latest. If you start building your mix as you track adding plugins as you go, then maybe. I have and old HD6 Accel rig in a Magma chassis running PT 8 & 10 on a Win 7 PC and a 8 core Mac Pro cheese-grater respectively for tracking and it’s just fine for that. YMMV!
Old 09-04-2019, 09:51 AM
JFreak's Avatar
JFreak JFreak is offline
Yea, unless "adding plugins as you go" (as in using same plugin versions on both ends) is a huge factor, then the only advantage of HDN would be 64 i/o limit compared to 32 i/o max for standard software.
Janne
Just Purchased Pro Tools Ultimate Reinstatement... Money is gone... No Software DruByrne Licensing & Accounts 2 08-30-2019 09:34 AM
Pro Tools Ultimate / HD Reinstatement? lampmusic Licensing & Accounts 10 06-18-2019 07:18 PM
Reinstatement give me older versions of pro tools? Thenewexhibit Licensing & Accounts 9 11-19-2018 01:13 PM
Pro Tools 2018 Reinstatement/Upgrade juliano42 Pro Tools 2018 3 04-23-2018 02:13 PM
Pro Tools Upgrade Reinstatement Plan with used license simon_lgr Licensing & Accounts 1 02-05-2018 07:16 PM
