Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Control
Old 11-22-2016, 10:21 PM
firmflange's Avatar
firmflange firmflange is offline
Default PT screen doesn't 'chase' Controls tracks...Help!
After updating to the latest firmware:
I noticed that when I touch a track icon on the Control, it will highlight the track on the PT screen (as it should), provided that track is visible on the monitor.
Now, say Protools shows tracks
15 - 20 on the monitor and I touch the "Track 1" icon on the Control.
With the new firmware, it will not automatically shoot up to show the highlighted "Track 1." on the monitor screen, so I have to scroll up to the highlighted track.
It did in the old firmware.
I've tried to look in all the settings and can't find anywhere that the PT will 'chase' the track icons. Can someone help me on this?
Old 11-23-2016, 02:11 PM
firmflange's Avatar
Default Re: PT screen doesn't 'chase' Controls tracks...Help!
Anybody? :)
Old 11-27-2016, 06:25 AM
crustn crustn is offline
I think there is a preference in eucontrol as well as in Pro Tools under Mixing->Control Surface. I don't use it so I cannot say if it's broken with the new firmware. What I'm doing is holding the ctrl key (mac) while selecting the track. This automatically scolls both edit and mix window to the selected track.
Cheers
Stefan
Old 01-10-2017, 01:52 AM
glennaudio glennaudio is offline
also check the setting on the iPad itself (cog wheel at the top right in the app). Turn on "control banks DAW" or something like that. you can't miss it
MacPro 5,1: 12-core 2.93 GHz 48GB RAM OS X 10.12.2 | Pro Tools HDNative 12.7.1 | HD I/O 8x8x8 | UA 4-710D | Avalon VT737 | Waves Diamond | Komplete 12 Ultimate Collector's | Kontrol S61 | Maschine Studio | Eleven Rack | Pro Tools Control w/ 9.7" iPad Pro | Pro Tools Dock
Old 01-10-2017, 07:00 PM
firmflange's Avatar
Thanks guys for your help, but I think I found it:
In Eucontrol Settings,
General Tab,
click "Dock automation mode buttons follow attentioned channel"
This solved it for me :)
Old 10-20-2019, 06:01 AM
danyg danyg is offline
having some similar question about Control App. What is the default behavior ?!?! I tried all the settings and options. Don't get it...
1.
- when I click a track in PT's mixer the blue rectangle follows in the App
- when I click a track in PT's Track List the App doesn't follow
in both cases the blue rectangle (bank) does nothing in the App, the mixer/bank in the app doesn't scroll. Shoudn't it though ?
2.
when I crtl+shift click to focus a track... is the Control App supposed to move/scroll or not - in my case nothing happens
3.
When I move the blue rectangle (bank) in the app, the PT mixer scrolls.
Vis Versa
When I scroll or click tracks in Pt's mixer the App does nothing
Mac Pro 12 core 3.46Ghz - 64 Gb ram - SSD 500 Gb - HD1 2T - HD2 2T - OS 10.10. - Mac Book Pro retina- OS 10.10. - SSL Alphalink convertor - Pro Tools 12 native - SSL Matrix console - Logic Pro X
Old 10-21-2019, 10:59 AM
firmflange's Avatar
1.
2.
3.
Vis Versa
Did you reset your Network (disable network, re-enable)? Turn off and disconnect your Artist. They are finicky at times. I do this before every session. Has it connected before?
PT 12HD Native / 192 / Yosemite / Cheese Slicer 3.33GHz 12-core / SSD Hard Drive / 32GB RAM
Slate Raven MTi2 / Artist Control
Old 10-22-2019, 12:23 AM
thanks for your answer, I was talking about the iPad control software. It seems (from another post) that everybody is waiting for an update
plugin controls only work on left side of screen ultralon Pro Tools 11 2 03-06-2015 05:46 PM
Works fine, but open screen doesn't appear ACP macOS 2 03-04-2013 10:27 AM
Alternates Match Doesn't Work - Screen Recording nathanaelj83 Pro Tools 10 0 10-10-2012 03:39 PM
Structure Beta doesn't fit my screen. wolfdavis Virtual Instruments 5 04-10-2007 11:18 AM
Help - screen doesn't scroll during record pixel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-07-2004 03:53 PM
