Old 02-18-2016, 04:19 AM
peterle peterle is online now
Default Copy IR + Presets from Space AAX (PT12HD) to TL Space (PT10HD) ?
I own support and update plan PT12 which includes Space aax license
(but not TL space btw) and installed the whole library...which is a pita
if you have to import each single library through the plug ins interface,
anyway , i did it and i like the plug in...
So i purchased also a used TL space (TDM)-plugin
( which includes btw the aax version)
for use with my PT10HD Accel setup as TDM version and as permanent aax license for PT12.
So in Fact i have 2 Setups:
PT10HD Accel on OS.X 10.8.5 with TL Space TDM
PT12HD (Native) on Yosemite with AVID Space AAX
Now few questions..
Is it possible to simply copy the IR-Library and Preset Folders
from my Yosemite PT12 Installation to my OS.X 10.8.5 PT10 Setup?
Or do i have to install manually the whole bunch of libraries?
And where are they stored ? could not find much information..
regards
foley artist , soundeditor
Old 02-18-2016, 10:03 AM
Top Jimmy's Avatar
Default Re: Copy IR + Presets from Space AAX (PT12HD) to TL Space (PT10HD) ?
Yes, you can just copy the impulse response folder. I don't know if the presets are compatible, but you can certainly try copying those too.
IRs: /Users/Shared/Avid/Space/Impulse Responses
Presets: /Users/(username)/Documents/Pro Tools/Plug-In Settings/Space
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2019.10, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 02-18-2016, 10:32 AM
thx
you know also where i have to store the ir-folder and plugin settings
for the use in tl space on pt10?
there are digidesign and trillium lab folders , not avid
installing tl space for pt10 is a pain , i had to create manually a
"trillium labs" folder because tl space refused to install libraries...
and only the simpliest presets show up now...
much simpler on pt12
HTML code is On
Space not able to 'see' all the presets that were created with TL Space ArKay99 AAX Plug-ins 12 01-29-2014 04:56 AM
TL Space Presets? tha]-[acksaw Virtual Instruments 19 09-15-2013 04:54 PM
TL Space TDM - Installing Presets/IRs Chief Technician macOS 0 03-25-2011 05:43 PM
TL Space TDM presets....Win7(64) ??... docric Pro Tools TDM Systems (Win) 0 01-06-2011 12:14 PM
TL Space presets,anyone got 'em?? docric Pro Tools TDM Systems (Mac) 5 06-23-2006 09:11 PM
